What if a 200tdi was our only option? - Defender Source
Old May 14th, 2016, 07:19 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I'm committed to my 200 as I had two 200 trucks at one point, and now have a 200tdi 110 and a spare motor, and a turner gas flowed head sitting around.
My plan is go get my backup engine rebuilt with the turner head, and add a new/rebuilt tranny(possibly r380), transfer case (1.2).
As a bit of a self proclaimed poser, I'm mostly concerned with road manners, open road, not mall parking lots.
My question is 2 part,
what else would be a good upgrade for a 200?
Is it worth shipping the engine to a rover specialist, or just have it re-built locally?
Old May 14th, 2016, 09:07 AM
Naplm00
Matthew
When I did my rebuild I did it at home. The hardest part was finding someone to do the line boring for the new cam bearing shells. I think they make them in sizes now.
I ended up putting In a knockoff allisport full width intercooler, boost pin and adjusted timing and fueling at the pump. Using a 1.2 disco case and 33in tall tires the only place I have issues is long long steep uphill grades and when towing more than 8000lbs.
I have minimal visible smoke except on startup. After the gauge install I'll probably go a bit hotter. It's be nice too find someone who can tune my pump lift with a dial gauge.
I'll be adding a boost gauge and egt later this year when I redo the cluster. I'm on the lookout for a turbo exhaust snail side as mine has a Crack under the waste gate valve from Aaron Richardet tuning the pump waaaaay hot on a 1.6tcase
How much did that Turner head run you?
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Good question. I would think the following would help. 1 bore it out to a larger cylinder. 2 larger intercooler. 3 different turbo, hybrid or vnt or twin. 4 larger exhaust 5 balance the rotating assembly 6 the most important, proper tuning. IP and timing.
I forgot one. Larger injectors.
Old May 14th, 2016, 09:28 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
I got the head on here for $1200
I don't think turner has them at the moment
Old May 14th, 2016, 09:30 AM
Naplm00
Matthew
Also it seems that alot of people are using 300tdi pistons for better econ/power
Old May 16th, 2016, 02:05 AM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Really? Is it as simple as just replacing the pistons? Or is it more entailed?
Old May 16th, 2016, 07:19 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
https://www.landyzone.co.uk/land-rov...-guide.254178/
Old May 16th, 2016, 08:29 AM
Naplm00
Matthew
I never read into it.
Old May 16th, 2016, 08:39 AM
??? Power and economy would not change. They have a slightly different combustion chamber location to match the different injector position. Other than that, it is the same engine.
Old May 16th, 2016, 08:47 AM
Naplm00
Matthew
Like I said above, I didn't read into it. I read in a few places that people were using 300tdi pistons for better econ/power.
Who knows,maybe they had a really tired engine before the rebuild? Maybe the change is piston shape improved mixture burning? Maybe it's bullshit? Maybe the 300tdi pistons are cheaper?
Ymmv
Edit: did five seconds of research. Looks like people are using 300tdi pistons and a 300tdi head on 200tdi blocks due to availability and price. They are reporting better power from they Hybrid engine.
Old May 16th, 2016, 09:03 AM
I would think that the increased power and economy are simply due to fresh components as there is virtually nothing to be gained there. The engines run similar compression ratio's and as John said aside from a slightly different injector angle are the same. The two put out pretty much the same power numbers stock.
200tdi, tdi
Our 8 year old dog bit our 2 year old daughter... hillstrubl Misc. Chit-Chat 62 July 8th, 2014 12:31 PM
Pics of our kids and our trucks. mjekogian Misc. Chit-Chat 35 April 4th, 2012 09:34 PM
Possible mechanical fan option... Hans Misc. Chit-Chat 9 October 19th, 2009 01:33 AM
Soft top repairs patching an option paulb Defender Technical Discussions 7 October 13th, 2006 03:44 PM
Disco Seat Option dnewman9 Defender Technical Discussions 2 January 5th, 2004 11:33 AM
