What holds this in place? - Defender Source
Old October 26th, 2009, 01:27 PM
c2sox's Avatar
c2sox
Al Cruz
93 110 #428 and 01 Disco SD7
I finally commited to start taking bits of my truck to start/attempt a restoration, I started with my wheels had them media blasted and repainted since I needed new tires. Next step was removal of the external cage and basket, well I got everything off except his part from the cage (see attached pics). Any idea if there's a stud on the bottom of the plate or is it just held in place to what looks to be some sort of adhesive silicone?
She looks kind of bald w/o the cage in the basket
ID:	22447   Click image for larger version
Old October 26th, 2009, 01:39 PM
Joeplumbo's Avatar
Joeplumbo
Joe PLumbo
1993 110
Hello Al,
If adhesive silicone try to get a length of fishing line underneath and pull it under the base. They should separate w/o too much fuss.
Joe
Old October 26th, 2009, 02:50 PM
mattarm's Avatar
mattarm
Matt
1993 D110
It is bolted to the interior roll cage. See Pic.
Name:	IMG_2785 (Large).JPG
Old October 26th, 2009, 04:38 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Yes, the interior rollcage comes into play
Old October 27th, 2009, 11:31 AM
c2sox's Avatar
c2sox
Al Cruz
Thanks for all the input, next that comes off is the roof. Hopefully that's going to be easy....hehehe
Old October 27th, 2009, 11:37 AM
cabell's Avatar
cabell
Cabell Crowther
Al,
What kind of suspension have you got under that 110?
Old October 27th, 2009, 12:35 PM
c2sox's Avatar
c2sox
Al Cruz
Originally Posted by cabell
Al,
This is the OME setup I have...
Front N115/764
Rear N44/754
Old October 27th, 2009, 12:55 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Your truck appears to be lifted. I suspect a two inch lift.
Dendy
Old October 27th, 2009, 01:06 PM
cabell's Avatar
cabell
Cabell Crowther
Front N115/764
Rear N44/754
And those are 33s you have on there? Looks great!
Old October 27th, 2009, 01:11 PM
c2sox's Avatar
c2sox
Al Cruz
Dendy
I want to say 3", but I think it's a 4" lift it's been a while. Here's a couple of pics for a better visual.
255/85/16's and Thanks!
ID:	22478   Click image for larger version
ac
Cheapest place to buy Tuffy console, Mantec snorkel Chris Cox Defender Technical Discussions 7 March 14th, 2005 09:21 PM
Cheapest place to get a new FRP? DiscoDino Defender Technical Discussions 8 January 10th, 2005 03:54 AM
Where is the cheapest place online to buy BFG MTs draaronr Defender Technical Discussions 4 August 25th, 2004 11:05 AM
removing clutch place from a/c compressor Campbell Defender Technical Discussions 2 May 1st, 2004 02:58 PM
Cheapest place to buy a tuffy center console JRowe Defender Technical Discussions 3 October 6th, 2003 10:42 PM
