What Grease - Defender Source
Old March 7th, 2009, 07:26 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
What Grease
Doing my clutch today, manual says use Rocol MV3 Grease. Is there a substitute grease i could get at a local Auto Store.
3rd low and BOOT IT
Old March 7th, 2009, 08:10 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mobil 1 Synthetic.
Legend in My Own Mind.
Old March 7th, 2009, 08:33 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Thanks Randy, Job got put off this weekend, Got sent the wrong clutch
3rd low and BOOT IT
Old March 7th, 2009, 02:37 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Jimmy,
How are you planning to change the clutch? Are you removing the engine/trans, dropping the trans, or removing your seatbox and lifting your trans up through the cab? Just curious. I have never changed my clutch and have always had a very clutch friendly style of driving, but with 100K I figure I will have to change it sometime. Curious at the easiest technique
Old March 7th, 2009, 04:33 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Not my pics but this is the way i got my trans out Chris.
http://nnin.net/gallery2/defender/clutch/
3rd low and BOOT IT
Old March 8th, 2009, 12:44 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I don't imagine there is a huge difference between a 90 and a 110, but it is quite easy from underneath to just drop the trans and transfer case together and swap the clutch. It only takes a few hours, and certainly seems a whole lot easier than pulling out the seatbox and all that that entails. IIRC it is worth your while to remove the tunnel cover, but everything else can stay.
Old March 9th, 2009, 12:50 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
whats left of the clutch, less than 5,000mls ago
3rd low and BOOT IT
Old March 9th, 2009, 01:19 PM
gnarly! how is the flywheel? looks like your clutch was slipping alot due to the stuck t/o bearing. I take it the t/o was stuck as we had guessed?
Old March 9th, 2009, 01:29 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Flywheel dosn't look to bad, just need a clean.
been exsposed for a week
3rd low and BOOT IT
One shot grease swivels thewap Defender Technical Discussions 11 July 21st, 2010 01:31 PM
The shocking "miracles" of Dielectric Grease.!!! Departing90 Misc. Chit-Chat 0 March 10th, 2008 09:29 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
leaking grease jimmy salmon Defender Technical Discussions 16 January 11th, 2007 09:55 PM
Leaking grease seal Rover- Girl Defender Technical Discussions 2 September 18th, 2006 04:11 PM
