What Gasket? - Defender Source
Old August 12th, 2016, 01:27 PM
RBBailey
RBBailey
1965 IIa
What Gasket?
Am I looking for here?
For under the flange where the oil line is coming in from the right side in this pic. Two bolts, roughly oval shaped. I think it must be: ERR1653
But want to make sure before I order.
Project:
1965 IIa SWB
Old August 12th, 2016, 01:30 PM
200TDI? Oil cooler thermostat?
It uses an o-ring. ERC5913
Allbrit.de - Ersatzteile für LAND ROVER & MG ROVER
Old August 12th, 2016, 01:40 PM
RBBailey
RBBailey
1965 IIa
For 300Tdi. Ah-ha, OK, thanks - but that only shows for 200tdi
Project:
1965 IIa SWB
Old August 12th, 2016, 01:48 PM
The 300TDi is the same part. The filter housing is a bit different, but the oil cooler thermostat and o-ring are unchanged.
Old August 12th, 2016, 01:57 PM
RBBailey
RBBailey
1965 IIa
Project:
1965 IIa SWB
Old January 29th, 2017, 08:28 PM
RBBailey
RBBailey
1965 IIa
To get to the 8mm flange bolts, you have to pull the filter, then the pressure sender, then the hose fitting. Once I got inside, I realized that somehow this seems to be a different part. There is no o-ring. There is a beveled gasket that fits between the housing and the flange.
First attempt to work on the truck in 5 months. It's now just bleeding all over the garage, and I have this feeling that I am in for another shock to my wallet before I can even get back to trying to put it back together.
Ideas?
Project:
1965 IIa SWB
Old January 29th, 2017, 08:56 PM
probably just an old o ring mashed to the shape of the recess in the housing
Ideas?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 29th, 2017, 10:00 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Gasket ERR3283, what made you think that there is an Oring there??
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 29th, 2017, 10:18 PM
RBBailey
RBBailey
1965 IIa
Ren Ching, I hope you are right about the old flat o-ring! I have to order a different one anyway, the one I have (ECR5913) is not the right size -- too big. Go figure... another bad/wrong part.
The reason I think it is an o-ring is because: Allbrit.de - Ersatzteile für LAND ROVER & MG ROVER
The leak is coming from where the #3 is = waxstat adapter. I think you must be referring to where the adapter housing fits to the block.
I have to put it back together as is and wait for the right o-ring. Not sure why this one is wrong, but I don't think it is supposed to have 1/2 inch of gap around when fitted.
Project:
1965 IIa SWB
Old January 29th, 2017, 11:16 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
https://www.landroverworkshop.com/di...ilter_53190#10 May help.
KGH - “Stinky LR diesel” Defender Snob
Old January 30th, 2017, 09:04 AM
roverman2010
1985 LR 90 200Tdi
Just take the waxstst housing part to any motor factors and get a viton o seal. The old seal beveled as the filter housing is chamfered for the o ring to sit in.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
4.0 V8 engine parts for sale (starter motor, upper gasket set, lower gasket set) bagocheetohs For Sale - Parts 7 August 11th, 2015 06:12 PM
Head Gasket Kit? Quimbola Defender Technical Discussions 9 November 5th, 2004 10:24 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 03:47 PM
replacing intake manfold gasket mattdh Defender Technical Discussions 1 May 27th, 2004 09:00 AM
poor gas milage / blown head gasket? got a read diff for a 94 D90? rover_rich_d90 Defender Technical Discussions 7 April 20th, 2004 02:11 PM
