What fluid for a lt85 tranny - Defender Source
Old September 16th, 2004, 10:09 PM
draaronr's Avatar
draaronr
Here
LR3
Book says motor oil. dealer doesn't know their head from their ass. So ATF, motoroil, or something mentioned in the double clutch column.
Old September 17th, 2004, 05:07 AM
Redline Mtf
Old September 17th, 2004, 10:00 AM
KeithD
Keith Duckett
90 V8 Import
You have an LT85? I thought NAS90s had R380s? I think my LT85 has ATF in it - should remember really. It can be very obstructive when extremely cold, but warms up quick enough once you have stirred the oil about. I am not sure any other kind of oil would make a difference. and I am not that bothered.
Old September 17th, 2004, 10:22 AM
draaronr's Avatar
draaronr
Here
LR3
Its a 1988 so non NAS. thanks for the tip
Old September 17th, 2004, 10:37 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
I think my lt85 has ATF in it also. Been awhile since I checked. I think I am going to switch to Redline. Anything to help smooth it out a bit.
Old September 17th, 2004, 11:10 AM
draaronr's Avatar
draaronr
Here
LR3
Do you get redline at Advanced auto parts or is it special?
Old September 17th, 2004, 11:30 AM
scrover
Steve Cooper
93 RRC LWB
Looks like it should be regular motor oil (you might have to enlarge the pages to read them):
Name:	90_and_110_p1 (Custom).jpg
ID:	1470   Click image for larger version
Name:	90_and_110_p2 (Custom).jpg
Name:	90_and_110_p3 (Custom).jpg
Old September 17th, 2004, 11:44 AM
draaronr's Avatar
draaronr
Here
LR3
Thats what my manual says, but it is 16 years old so things change, that's why I wasn't sure.
Old September 17th, 2004, 11:47 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
Aaron,
Redline says you can use there MTL in place of motor oil in a manual trans. You can order it online from Summit Racing, JEG's and a number of other sources. It is a bit pricey, $7.95 a quart. I think I will be trying it during my next fluid change.
Old September 17th, 2004, 12:02 PM
draaronr's Avatar
draaronr
Here
LR3
you don't happen to know how much it takes to fill it.
Old September 17th, 2004, 12:07 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
am guessing about 3 quarts. But that is only a WAG
Old May 8th, 2012, 09:55 AM
Smirk1010
Justin
1986 3.5 V8 Ninety
Old thread, but did anyone end up using Redline MTL on their LT85? If so, how did it work out?
Old May 9th, 2012, 06:58 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Why would you do that? Use a good high shear oil like Rottella......not the synthetic either. Keep it simple.
Matt Browne
Old May 9th, 2012, 11:17 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Normal 15/40 engine oil is what it shows in my workshop manual.
Old May 9th, 2012, 06:29 PM
Smirk1010
Justin
1986 3.5 V8 Ninety
I guess my question was the same as the original poster. I see 15W50, 15W40 listed in the manual but wanted to know if there was a general consensus on something that works better. Thanks for the info.
Old May 9th, 2012, 06:36 PM
Pardon my ignorance, but are the specs diffeent on an LT85 vs the LT77/R380 oil needs? Seems like many folks - myself included - run Redline MTL in the LT77/R380...was just curious if the LT85 is that vastly different.
Old May 10th, 2012, 06:52 AM
LRover's Avatar
LRover
J. Michael McCaig
The LT85 and LT95 use motor oil as per the manual. The LT77 and R380 use ATF as per the manual. What ever fluid or transmission type you have, it is important to change the fluid regularly.
Old May 10th, 2012, 10:08 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
MTF (a fuid designed expressly for use in a manual transmission) is probably the best choice. Not cheapest, not easiest to get, but probably best. It miiiiight give you slightly better shifting and your shifting might stay smooth for longer. All of this is a maybe. Just avoid GL5's in general since many of them eat up the brass/bronze parts faster than GL4/MTF/motoroil/ATF
Stv
Old May 10th, 2012, 01:02 PM
I believe MTL and MTF by redline both have motor oil ratings I just can't recall what they are at the moment.
Old May 10th, 2012, 01:20 PM
For an LT85, Redline MT-90 (not MTL) would be the correct choice and would be better than motor oil. MT-85 might be a good choice for cold climates.
http://www.redlineoil.com/content/fi...PDS%208-10.pdf
http://www.redlineoil.com/product.aspx?pid=46&pcid=7
tranny quit on me need to source problem, fix quickly myself airbornrover Defender Technical Discussions 0 January 6th, 2009 04:36 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
Tranny leak?? mspell Defender Technical Discussions 3 September 8th, 2004 12:43 PM
