What engine is this? - Defender Source
Old February 23rd, 2015, 02:22 PM
SidewaysWaffle's Avatar
SidewaysWaffle
Dan Capo
Loading..
I apologize for my ignorance but can anyone tell me what engine this is based on serial number? Did a search but would appreciate another opinion!
Old February 23rd, 2015, 02:26 PM
Let me google that for you
Old February 23rd, 2015, 02:27 PM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
Google is your friend: Reconditioned 300tdi, at least according to that part number.
stc1736e
1989ish 110 300tdi (Bella)
1988 LR90 ST 200tdi (Shorty)
1991 D130 200TDi (TBN)
Old February 23rd, 2015, 02:38 PM
SidewaysWaffle
Dan Capo
Loading..
Thanks fellers.. I found the block and pistons but no head or ancillaries. Worth picking up and piecing together?
Old February 23rd, 2015, 02:40 PM
ezzzzzzz
Mark Garrenton
$25 scrap weight.
Old February 23rd, 2015, 02:48 PM
SidewaysWaffle
Dan Capo
Loading..
Originally Posted by ezzzzzzz View Post
$25 scrap weight.
Is this really worthless? I figured maybe I can rebuild it and slowly source all the parts. Trying to save a 300tdi here someone shine some light!
Old February 23rd, 2015, 02:53 PM
61rover's Avatar
61rover
John Crouse
Depending on condition I would not see any reason not to save it.
Old February 23rd, 2015, 03:05 PM
SidewaysWaffle
Dan Capo
Loading..
You tell me.. I can scoop it all up for $200
Old February 23rd, 2015, 03:08 PM
My thinking is that if you didn't realize it was a 300tdi you may not be familiar enough to do the rebuild yourself and will be paying a shop to do it?
Old February 23rd, 2015, 03:11 PM
SidewaysWaffle
Dan Capo
Loading..
Absolutely not, new to the defender world, not new to engines. I rebuild BMW engines on a frequent basis. This will be cake for me
Thoughts on condition?
Old February 23rd, 2015, 03:12 PM
The problem is you are missing so much, I'm not sure what you would save if anything.
The second problem, is the block could be cracked and that is why it is there.....
Old February 23rd, 2015, 03:15 PM
SidewaysWaffle
Dan Capo
Loading..
There is a reason it was disassembled. Id want to know why before Id buy it.
It comes with sway bar mounts too?
-Jeff
Apparently only block and pistons come with it.
It was removed because of a knock which was later diagnosed as the crank being the culprit
Old February 23rd, 2015, 03:26 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Jeff, those are just rod bushings. Makes the truck vibrate less
Old February 23rd, 2015, 03:28 PM
SidewaysWaffle
Dan Capo
Loading..
So no crank, cam, bearings, caps?
-Jeff
Look at the other picture for the caps, would replace bearings, and no crank as that was the issue in the first place apparently
Old February 23rd, 2015, 03:49 PM
I would consider it potential spares for an engine you don't have ...
You could make a Top Gear table .... now that would be cool!
Old February 23rd, 2015, 04:02 PM
SidewaysWaffle
Dan Capo
Loading..
Ahah, I used to have a BMW I6 block as a coffee table/wine rack
Old February 23rd, 2015, 04:03 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
i would pay you to make the coffee table for me. =)
Old February 23rd, 2015, 04:16 PM
yes, it is this one
Old February 23rd, 2015, 04:21 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Originally Posted by Ren Ching View Post
yes, it is this one
Man. Josh is slipping.
Old February 23rd, 2015, 04:23 PM
I see little value in the pile of parts there.
Without a crank I'd agree its pretty much worthless unless you needed spares.
engine
for sale 300tdi engine/box/rad/intercooler/engine mounts ect leachy For Sale - Vehicles 6 September 8th, 2008 08:11 PM
Engine Oil Pouring from engine dfscott Defender Technical Discussions 46 June 18th, 2007 09:45 AM
