What else to check - Defender Source
Old June 11th, 2007, 09:01 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
What else to check
I have a bad steering wobble, look out the window and it looks like the wheel is gonna come off. I have fitted new radius arm bushes, checked and re-packed the bearings, fitted new stub axels, had the wheels balanced (lost 6oz last time out). Steer to the left when standing front end goes to the right, brake and truck is all over the road, ball joints ect look ok to me
3rd low and BOOT IT
Old June 11th, 2007, 09:48 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Panhard rod bushes?
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 11th, 2007, 10:56 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
i did a search and everything seemed to point to pan hard rod but mine looked fine, i replaced them about a year ago. mind you i have been in 3rd low and booting it at rock climbs. will do them and see what happens
3rd low and BOOT IT
Old June 11th, 2007, 11:01 AM
swivel preload. check it.
Old June 11th, 2007, 11:11 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Jimmy remember to look at the bolt holes & the bolts....
Old June 11th, 2007, 01:17 PM
Cirbo's Avatar
Cirbo
Jim C.
what rob says... X2
Old June 12th, 2007, 06:54 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
pan hard looked good but took it out anyway, the metal center tubes had seperated from the rubber and putting a long bar in there made for alot of movement. holes and bolts are fine, will get new bolts tho to be on the safe side. anyone know the size of the nut on the drop arm, biggest i have is 35mm and its a bit small (truck is a 94) small amount of play.
3rd low and BOOT IT
Old June 12th, 2007, 08:38 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Last resort = Is it the rim? I had one do that cause a lug nut got loose and chewed up the rim. Oblonged the lug hole. Switched to the spare and it was fine.
"It's not a Jeep"
Old June 17th, 2007, 06:42 AM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
fixed, panhard bushes
3rd low and BOOT IT
Old June 17th, 2007, 01:22 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
Congrats!
So does that mean well see you in Fitchburg next weekend?
Old June 19th, 2007, 12:02 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Originally Posted by pmd
Congrats!
Looks like its going to be a BSROA only event as they are supplying food ect
3rd low and BOOT IT
Old June 19th, 2007, 12:34 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Last I heard it wasn't... they seem to be letting me go and I'm not a member... I think they might come up with a fee though.
Old June 19th, 2007, 02:22 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
I guess it's a good thing I joined a couple months back..
Old June 20th, 2007, 10:32 AM
cellulararrest
Chris Snyder
After a few phone conversations and a few emails, it has been decided that there will be no fee for this weekend.
Looks like we're all set.
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
