what does this plug in to? - Defender Source
Old November 2nd, 2004, 02:09 PM
mattdh's Avatar
mattdh
Matt Hurst
this plug comes off the pass. side. if some one can trace it for me- it comes of the wiring of the pass. side fuel injection wiring and the stepper motor wiring behind the intake manifold.starts back there and is about 3 or 4 feet long?also the washer fluid pumps for a sw-the washer bottle has 2 pumps on it one plug is black and one plug is white- does the black plug go to the pump closer to the heater or to the pump closer to the radiator res.
Old November 2nd, 2004, 02:33 PM
That goes to the evaporative canister which is attached to the same bracket as the PS pump, except its hidded up under the fender behind the headlight. I have a pic at home that will help if the explanation isnt clear enough.
I just noticed, damn that engine bay is clean!
Old November 2nd, 2004, 02:48 PM
mattdh's Avatar
mattdh
Matt Hurst
thanks jim thats what i kind of thought - i guess i will have to unbolt and pull that out becuase i cant see where it goes with the canister tucked up in there. thanks again!!!!!!!!!!
Old November 2nd, 2004, 05:49 PM
Here is the pic I mentioned, maybe you can get a good enough idea of the assembly to reach in and feel around without having to take the stuff out, I dunno.
Name:	Charcoal Canister.JPG
Old November 2nd, 2004, 07:45 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Matt,
Your engine is soo clean!!!! I have engine envy. My 4.6 is covered with mud from a recent trip...
Old November 2nd, 2004, 09:28 PM
thelandroverguy's Avatar
thelandroverguy
Vince
1997 D-90 ST
Wow, same here. Was that a rebuild or ? The engine and bay look new.
Old November 2nd, 2004, 11:59 PM
mattdh's Avatar
mattdh
Matt Hurst
jim -i did find it earlier without having to pull it out-thanks again for the help!!!! vince and jim-its my project,i have galv. the frame, replaced the bulkhead, had it painted pastel green and put in a 4.6 block in.thats just the big details.
OBD Plug no power??? Cyborg Defender Technical Discussions 4 December 29th, 2005 11:29 PM
What does this plug go to??? Chris Cox Defender Technical Discussions 1 July 11th, 2004 03:24 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
Serial Link Mating Plug? Ramsay Defender Technical Discussions 9 May 13th, 2004 11:27 PM
97 radio plug arrangements Gkase Defender Technical Discussions 1 October 6th, 2003 06:58 PM
