What does proper fuel timing look like? - Defender Source
Old October 31st, 2014, 06:46 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
I am fiddling with my fuel timing… trying to get it just right. Runs/starts easily. Pulls well depending on my fiddling.
I read around the internets.. and it talks about "more than usual" smoke of various colors. I've never owned a mechanical injection diesel, with no emissions control. I have no idea what "usual" is. I'm not even sure what a knock is in a clattery ol' diesel. I assume its a "tap tap tap"
When cruising, I should be seeing no smoke. I assume black is what I want to see when giving it "too much" pedal. I currently see… Just whisps of black when I am trying to keep up speed up a hill or do my best to keep from slowing down traffic when starting at a green light.
So, loud and knocking is advanced…
Quiet and super black smoke is retarded?
Tons of grey/blue smoke on acceleration is also advanced?
Knocking is bad for you…
So I just want to be, low amounts of black smoke, increasing with pedal under load, and only under "more pedal than it can use" acceleration, medium loud, no knocking?
(I think I've got a touch of knock right now under medium load turn injector pump clockwise while facing from radiator to retard?)
I think I've got this… just checking with the big brains.
Old October 31st, 2014, 06:58 PM
what engine ?
Old October 31st, 2014, 07:07 PM
His registry says 2.5NA.
Old October 31st, 2014, 07:09 PM
DefenderMd's Avatar
DefenderMd
Ben
what engine ?
Yea, 2.5na… but it should be fairly inconsequential. Any mechanical injection light duty diesel would be roughly the same yea? Barring any goofy quirks.
Old October 31st, 2014, 07:18 PM
asked because I have ever known anyone with a na who thought their truck "Does 60mph rather quickly".
My advice would be to do nothing to the ip. The enemy of good is better. If the truck starts easily and seems peppy, these are things the lucas pumped 2.5 aren't exactly known for. Sounds like you have a good one.
Old October 31st, 2014, 07:21 PM
asked because I have ever known anyone with a na who thought their truck got up to 60 quickly.
Mine hauled ass down steep hills.
Old October 31st, 2014, 07:23 PM
DefenderMd's Avatar
DefenderMd
Ben
Did I say that?
Oh.. well… quickly… as opposed to slower than i could. I mean, its faster to 60 than me on a bicycle…
Right now it'll get to and hold 60 fairly decently.. 0-40 is kinda crummy but 40-60 is not too too shabby. It doesn't accelerate much slower than i usually do in my 3.6 JK.
Difference being, I have plenty of pedal left on the JK to be polite and cut into traffic, the 2.5 is doing its best to go slowly. It seems to be a fairly fresh engine. Not new, but not worn out either. I don't know as it goes with the truck. Other people with 87 era 110s have engines painted different from mine. Mine is sand cast bare aluminum intake and a dark ruddy brown painted block with a black painted head.
Old October 31st, 2014, 08:19 PM
If it revs up freely to the limiter it is not too advanced. It will also ping too much. You want to find the max power point.
Put a good scribe line on the pump so you know where you start and try small changes until you find he best point.
Old October 31st, 2014, 08:28 PM
DefenderMd's Avatar
DefenderMd
Ben
By revving freely, you mean it will otherwise hesitate or skip?
I think I'm close to the max power point... just trying to make sure I don't do more harm than good. Sometimes fastest is also shortest lived... sometimes the opposite.
fuel
Does this stuff make my butt look big? Am I over weight? coffee Defender Technical Discussions 12 September 15th, 2014 09:25 PM
Does everything look ok under here to you guys? svxaddict Defender Technical Discussions 10 May 21st, 2014 06:24 PM
What does a Amur Tiger look like coming out of a Defender? dlane Misc. Chit-Chat 11 April 21st, 2011 11:55 PM
Does this look normal? Front Springs bjf Defender Technical Discussions 9 May 17th, 2009 09:40 AM
This just does not look right... Stmpede Misc. Chit-Chat 8 May 2nd, 2007 12:59 AM
