What do i have and what are my options? - Defender Source
Old December 12th, 2015, 05:31 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Finally got around to setting the 2 engines side by side and noticed the bellhousing difference.
Is there a short bellhousing version for the ZF auto or am I stuck with fabbing new mounts and new drive shafts?
I'm thinking about just keeping the LT77.
The motor autobox and Tcase came out of a Rangie. Will the Tcase be a bolt on swap?
Sorry for the newbie questions.
Old December 12th, 2015, 05:32 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Picture this time
Old December 12th, 2015, 06:12 PM
I don't think so as they did not do the Defender with an auto. The autos are all from Discos so long bellhousing.
Old December 12th, 2015, 06:16 PM
Disco 200tdi with short bellhousing into a LHD is very hard to do.
Old December 12th, 2015, 06:25 PM
all tdi automatic bell housings are the same. It will all bolt right up and will also clear your lt77 floors. The trans frame mount needs to be used.
Old December 12th, 2015, 07:29 PM
the rover shop
shayne young
And depending on what Range Rover it came out of the transfer box may be the viscous coupling type....best to put a manual diff lock transfer box in it..
Having said that I see in the pic that it appears to have the manual diff lock selector unit...so you are good to go..!!
Old December 12th, 2015, 07:54 PM
carlosz's Avatar
carlosz
Carlos
because of the torque converter it is not physically possible to have a short bell housing auto box.
Old December 12th, 2015, 09:25 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Can I bolt the TC (1.2) off the ZF auto onto the back of the LT77 or will I need to change out the shaft?
Old December 12th, 2015, 09:39 PM
It will move over.
Old December 12th, 2015, 09:40 PM
The picture appears to be a complete 200TDI Discovery drivetrain.
Old January 1st, 2016, 05:04 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Oil Cooler line
Now it's on to the oil cooler lines.
No oil cooler lines on the engine, but picture shows the bolts that are plugging the holes.
From the Glencoyne website:
1. If converting a 2.5TD or late military 2.5NA with oil cooler built into the radiator you already have a suitable set of pipes. Around the end of 1992 Land Rover changed the design of oil cooler pipe union on the Discovery. Older engines have round-ended oil cooler pipes, the same as the 2.5TD. Later engines have pipes with a flanged end and O ring. If you want to use 2.5TD pipes on a later engine you will need to swap over the oil filter housing for the 2.5TD one, and swap the adapters on the oil cooler for the ones on your old oil cooler (taper thread, very tight and hard to shift).
3. Buy new Defender oil cooler pipes. Part number for the older type unions is ESR280/ESR281, for the later type ESR1912/ESR1913.
Which do I order?
Name:	oil cooler 1.jpg
Hit and Run...but caught him - Options? bennett Misc. Chit-Chat 32 November 20th, 2013 12:55 AM
Heads that only have been rebiult once need to have tappet/lifter gap checked? Neil McCauley Defender Technical Discussions 4 December 14th, 2011 03:19 PM
Trans and t case options for 300tdi dogbite Defender Technical Discussions 12 November 10th, 2010 03:04 PM
Tire carrer and fuel can rack options? wicks Defender Technical Discussions 8 October 13th, 2008 11:14 AM
Current headliner and side panel options? PCRover Defender Technical Discussions 10 June 12th, 2007 03:38 PM
