What diameter is the plastic fuel line on a LR diesel - Defender Source
Old June 23rd, 2010, 09:05 PM
I need to repair a cut in a line and the repair kits are all based on sizes and they are so close it is tough to measure.
Old June 23rd, 2010, 09:27 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
When I did mine ACE hardware had the parts to splice the line in the plumbing section, just take down the cut off part with you and it is easy to figure out from there.
sorry I do not remember the size
Old June 23rd, 2010, 09:30 PM
Ok thanks.
I ordered some 5/16ths on ebay so hopefully that works. I have some rubber line over it now but that is a temporary solution.
Old June 23rd, 2010, 09:50 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I wouldn't use hardware store hoses for fuel line purposes, it's just as easy to take a sample with you to a auto store and cut off a length of proper grade of rubber hose.
Old June 23rd, 2010, 09:56 PM
That is just the thing. It is a nylon line so a rubber patch will not cut it.
Old June 23rd, 2010, 10:03 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I just replaced the whole thing with rubber fuel rated hose from NAPA. People say it's not good for Biodiesel, but I don't care, and you don't have to deal with the plastic crimping and getting brittle either.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 23rd, 2010, 11:07 PM
So what you did was cut the nylon off completely and run rubber from steel to steel with clamps?
Old June 23rd, 2010, 11:26 PM
IIRC, its 8mm on my tdi, so 5/16 should be right on. Of course this is for your early truck, so heaven only knows whats on that thing.
Old June 24th, 2010, 12:01 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Exactly. Looks a lot cleaner too.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 24th, 2010, 12:18 AM
Ok, this sounds like a winner buck. It is not the the diesel runs at high pressure.
Ron
Old June 24th, 2010, 12:23 AM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
I did the same thing Buck did. Cut the old plastic fuel line off and use good 5/16 rubber fuel line with nice zebra hose clamps. 8 years and 100K later and no issues.
Cheers
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old June 24th, 2010, 12:26 AM
Sweet, thanks. Looks like I wasted $9 on ebay, but whatever.
Old June 24th, 2010, 12:58 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Just to clarify I did not use hose or tube from the hardware store, I used some brass couplings to join the old 2.5 fuel line to the 200tdi fuel line.
Rover also offers the little brass bits, but the ones from ACE worked just fine and I did not want to wait to get them from the UK
STC935 2.32 connector
STC936 0.26p olive
STC937 0.65p nut
Old June 24th, 2010, 11:00 AM
Most of the fuel line is 3/8". Some is 5/16". It is all nylon. Nylon tubing is the best thing to use for fuel line. Much better than hose plus it is very cheap and easy to find.....
When using compression fittings, make sure you use an internal sleeve.
Old June 27th, 2010, 06:32 PM
JSQ's Avatar
JSQ
Jack Quinlan
Let me guess, this $9 piece of fuel line on ebay.co.uk was attached to a tattered zebra stripe 1983 2.5NA 90 that comes with the purchase of the line.
Delivery sometime next month?
Old June 27th, 2010, 11:09 PM
LOL no. It was 6 barb fittings shipped. I bought some regular fuel line but the whole thing is nylon way far back so I now have plan D or so which is a new lift pump. The lift pump supersedes (how many people spell this word correct) to the 200tdi part and it comes with the fittings to adapt to the factory line. $67 at rovahfarm and doug says the lift pump was not pulling fuel so ....
Ron
Old June 27th, 2010, 11:21 PM
I really do not understand why people are scared of the nylon tubing. It is available everyone and costs nothing. Most of the connections are simply heat slid over steel tubing. All that you need to do is lube the tube, heat the steel tubing and slide the nylon on when it gets hot enough to be formable. The stuff is cheap and easy to work with.
Old June 27th, 2010, 11:23 PM
I fear everything that is not galvanized steel.
Seriously, I need the lift pump anyway and it kills two birds with one stone.
diesel, fuel
Diesel Fuel Filter/Primer Michael Defender Technical Discussions 16 August 15th, 2006 12:45 PM
Fuel line valve cracking RickM Defender Technical Discussions 2 October 21st, 2004 11:15 PM
