What clutch kit do I need? - Defender Source
Old May 2nd, 2012, 08:19 AM
I've got an 85 110 with a 300tdi and an Lt-77. My throwout bearing is bad, and the clutch is on its way out, so its time to order a clutch kit. I'm a little confused on whether I order a clutch and pressure plate for a 300tdi or an lt-77. Its in Microcat under the engine section, so that leads me to believe that I should just order one for a 300tdi. I assume I need a throwout bearing for an Lt-77 rather than a 300tdi.
Old May 2nd, 2012, 10:25 AM
Can anyone confirm if p/n 8510314 will work?
Old May 9th, 2012, 01:36 PM
Anyone?
Old May 9th, 2012, 01:57 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
the throw out bearings are all the same
Old May 9th, 2012, 02:30 PM
Thanks! I figured I needed one for an lt77 anyway, but I'm still unsure about the clutch and pressure plate.
Old May 9th, 2012, 03:10 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
check your inbox
Old May 9th, 2012, 03:51 PM
200 and 300TDI use the same clutch and LT77/R380 use the same release mechanisms.
clutch, kit
defender clutch kit... the rover shop For Sale - Parts 4 September 6th, 2012 04:00 PM
Clutch Kit kzack For Sale - Parts 0 September 12th, 2010 10:26 AM
Clutch Kit Install Cost? mikeybob2@msn.com Defender Technical Discussions 5 July 22nd, 2009 05:22 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
