what bump stops ? - Defender Source
Old January 17th, 2018, 03:44 PM
what bump stops ?
Anyone know what bump stops the stage 3 safari gard lift used ?
Guenning they were 3 inches longer ? Polyurethane ?
Old January 17th, 2018, 04:09 PM
I do not know for sure, but they looked like Polyurethane Procomp Bump Stops 69090/69091 to me
edit:
looks like Daystar makes a cheap version: KU09014BK for 3", KU09009BK for 4.5"
Old January 17th, 2018, 04:49 PM
Thanks Ed, according to the brochure Lav has posted on the web they were urethane. The procomp ones use a single stud as opposed to being bonded to a mounting plate.
I like the daystar black ones- but cant find any dimensions on the mounting plate size.
Found this picture of an early SG stage 2 setup
Old January 17th, 2018, 05:24 PM
np doug
I think there's enough room above each stop on the frame to use a nut to tie the stud mount down and then chop off the excess stud. Some 1/8" mild steel through a drill and bandsaw/sawzall with some rattle-can should work as a mounting plate.
I have no idea how the originals were retained though
top
RTE Shock Mounts, 8" Fox Shocks, Extended Bump Stops SMac Wanted 2 February 24th, 2013 07:39 PM
Terrafirma/Polybush Extended Bump Stops crown14 For Sale - Parts 2 December 17th, 2012 06:09 PM
Extended bump stops CDeWan Wanted 0 September 29th, 2010 01:13 PM
High Quality extended bump stops Roadsiderob Defender Technical Discussions 3 August 28th, 2006 03:19 PM
Bump stops UpnOver Defender Technical Discussions 4 May 7th, 2005 11:55 AM
