What brakes do I have(axles too)? - Defender Source
Old January 4th, 2010, 07:52 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
Cool What brakes do I have(axles too)?
I have a '84 d-90 200 tdi. All is well and I know or am familiar with most of the truck's parts(ie which trans, transfer case, filters, etc. the vehicle has). But, the truck was imported from the UK and it has disc brakes, front and rear(I imagine it did not come originally with rear discs). I am hoping that someone can tell me an easy(or not so easy) way to determine what brakes are on the truck. The axles are defender and one of the service receipts mentions an upgraded or replacement rear axle. I don't need brakes yet, but, I'd like to know what I'll need before I am confronting the need for new brakes. Any help would be greatly appreciated.
Old January 4th, 2010, 08:23 PM
Post some pics, so we can get a better idea. A picture of the hubs would be helpful too. If someone went to all the trouble of putting discs on the rear, I would guess they did not leave the 10 spline axles.
Old January 4th, 2010, 08:40 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
they should also have a number on the top of the tubes.
Old January 5th, 2010, 05:30 PM
isleofbones
Mike Deery
1984 D-90
Dave,
Pardon my ignorance, but, do you mean the tube part of the axle?
Scott,
I will try to post pics this weekend, if the weather isn't too cold for this New York sissy!
Old January 5th, 2010, 05:54 PM
Yes, on top of the axle tube.
Old January 5th, 2010, 07:29 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The number on the tube will only tell you about the tube, everything else can be and could have been switched out. I know I had a 10 spline RRC classic rear axle, then swapped to ABS stubs and hubs with a 24 spline Detroit 3rd, then eventually changed to an ARB locker, then swapped out the rusty axle housing for a Disco 1 housing.
Old January 5th, 2010, 07:52 PM
That is certainly true.
Old January 5th, 2010, 07:53 PM
jetmech's Avatar
jetmech
Dave McHenry
True about the number but that along with the picture will tell the story. Many UK imports will not have the axle altered from original.
Old January 5th, 2010, 08:56 PM
Except, the OP's truck obviously is altered.... Disc brakes on a 1984. Most likely, it has a Disco or RR classic rear axle.
Old January 5th, 2010, 09:01 PM
jetmech's Avatar
jetmech
Dave McHenry
[font='Times New Roman', 'serif']What I found was most will swap a complete axle and not inter mix the parts.[/font]
Old January 5th, 2010, 10:07 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
There are really one type of rear pads that go on a rear disc D90/RRC/Disco1, and one type of front pad that go on a Defender but another type of front pad that go on a Disco and yet another that go on some RRC's.
There are two different calipers that can go on the rear of RRC/Disco1/D90 early caliper will be held on with Imperial threads the later and proper to a 90 will be held on with a fine metric thread.
The fronts, I'd have to see a pic of the caliper.
Pictures of the drive flanges can also help with identification.
Keith
Big, Red and ... aaa Red..
Old January 18th, 2010, 05:29 PM
isleofbones
Mike Deery
1984 D-90
what kind of brakes do I have?
Thanks for the helpful info guys. Just as I was getting to remove the wheels and take pix for some help identifying my brakes, I was lucky enough to get in touch with the previous owner in the UK. He informed me that my 1984 d-90 has standard d-90 disks in the front and the rear axle was switched out for a range rover classic, including the standard discs on those axles.
Thanks for all the advice,
axle, brake
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
Wheelies and brakes! TwisteD90 Defender Technical Discussions 7 January 10th, 2006 10:31 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Brakes: Slotted & Drilled or Not mhansen Defender Technical Discussions 2 March 29th, 2004 03:06 PM
Need rear brakes...DIY?? P1CR Defender Technical Discussions 17 March 6th, 2004 03:46 AM
