What are those for?? - Defender Source
Old April 6th, 2011, 07:45 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
On my 110, under the rear cross member, there's 3 welded plate with hole in them. One's in the middle and two other on each side. they're under the rear cross member. I wanted to weld a hidden hitch and found these.. What are they for?
Jeff
------ Follow up post added April 6th, 2011 07:49 PM ------
If I'm not clear.. Ask me questions! It's not that simple to explain..
Old April 6th, 2011, 09:03 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I believe the NAS style bumper and other tow hitch arrangements bolt to the crossmember in those locations. I didn't add them when I rebuilt my crossmember because I didn't have anything that required them.
Old April 6th, 2011, 09:07 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
Hmmmmm... It's not an NAS 110 but an Ex-Mod one.. I have the military tow hitch ( like a claw) but these thing are right under the cross member.. I want to had a "hidden hitch" so I can tow the chipper and the wood splitter for work. I have a sankey trailer as well, hence the military hitch..
Old April 7th, 2011, 01:19 AM
TS888's Avatar
TS888
Tony Sims
1984 110
My chassis is military, it has the same plates. They aren't for the non-NAS hitch, because the truck had one and it wasn't bolted (rusted) to these points.
The MOD and other military users have eleventy seven accessories that bolt on the 110, could be for anything.
Tony
1984 110 "Smokey" (sold)
Old April 7th, 2011, 02:56 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
All euro spec rovers have these, the rear (flip down) step uses the LH ones, and the 3 that are centrally placed are used for the angled piece of steel that helps support the adjustable height tow hitch.
and also used for fuel tank guard mountings.
http://www.paddockspares.com/pp/SHOP...ges/202047.jpg
you can see the holes in the angle iron thats mounted horizontally on that hitch frame.
and this flip down rear step is what uses the LH holes;
http://www.rimmerbros.co.uk/ProductI...GRID007587.jpg
Old April 7th, 2011, 07:37 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
Oh, I see! says the blind man.. I'll have to come up with a new plan then... Anyone with an European 110 has put another hitch ? I need the nato hook and a regular hitch for occasional towing..
Jeff
------ Follow up post added April 7th, 2011 08:28 AM ------
Anyone can tell me where the two sides arms are supposed to attach to? Their angle looks like it's not on the rear crossmember.. On the frame rails perhaps?
