What are these wires? - Defender Source
Old February 16th, 2012, 12:23 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
Pulled of my instrument panel to replace bulbs with LED's and noticed these 3 unattached wires.
Figured one of you guru's will recognize them in a split second without me needing to trace them.
Any ideas?
Old February 16th, 2012, 03:23 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Probably part of the instrument wiring. Dash light +, key on + and a ground. An extra for different type guage used in another application. You can follow them back to their connector and use their colors with a wiring diagram to find out exactly.
legend in my own mind
Old February 16th, 2012, 03:54 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Im thinking they are for a aux fog light switch? I remember using them in the past. but my memory is getting bad.
you could run a test I think they will get power on low beam only, but its been awhile since I messed with them .
85 D110 3.5 3 DR
Old February 16th, 2012, 04:47 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
There are 2 'spare' light connectors behind the dash of a 97. Both are blue but with different color traces. From memory I think one is Orange (high beam?) and the other Grey (low beam?). Those might be your blue ones. The red one I have no idea but if it has a white trace then its a dash illumination source.
Like Ed says though, put a meter on them and start flipping switches to see when they power up.
Old February 16th, 2012, 06:42 PM
Low fuel and fog lamps?
Spark Plug/ ignition wires mdmccallum Defender Technical Discussions 3 September 1st, 2005 11:48 AM
Magnecor plug wires jabber Defender Technical Discussions 4 June 26th, 2005 02:07 PM
Running speaker wires to rear artm Defender Technical Discussions 6 December 13th, 2004 02:42 PM
hiding the overhead ralleye lamp wires GeoParth Defender Technical Discussions 1 March 29th, 2004 04:03 PM
Best Ignition Wires? wicks Defender Technical Discussions 7 February 22nd, 2004 10:10 PM
