What are the body capping options / differences? - Defender Source
Old August 7th, 2009, 08:40 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I'm starting to plan a few repairs I need to do over the next couple years, and pretty high on the list is new body capping. The driver side still looks fine, but the passenger side needs to be replaced. And, of course, the NAS parts are no longer available.
What are the other options that I have for this? What was different in the NAS parts anyway, compared to the stuff available now?
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 8th, 2009, 03:45 PM
If it just has a couple bad places you can patch it with some good bits from another rusted out one. This is what Cgalpin and I are/have done.
Almost all of ROW ones will have the part that juts in where the bulkhead behind the seat is.
Old August 8th, 2009, 10:48 PM
Hans's Avatar
Hans
Hans Haase
Mine's got too many big areas rotted out. So either way I'm going to have to piece together a full one.
The truck was originally a soft top, now a wagon, and still has the rear corner supports for the safari cage. That's what really caused a lot of my problems in the back.
-Hans
Well, I was able to dig up what I THINK are the non-bulkhead part numbers AMN710160 and AMN710170. Now, I just need to find the damn things somewhere.
-Hans
My oil line fix
Old August 9th, 2009, 10:44 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Last time I was at George's warehouse at RDS. He had a lot of new and also a lot of slightly used cappings. I was able to find enough to do on my doublecab 110 and I was able to get some for the rear corners which vary depending on the tail light configuration.
Old August 9th, 2009, 12:49 PM
Hans's Avatar
Hans
Hans Haase
I'll have to give George a ring. I just need the top capping, corners are fine.
My oil line fix
body
Galvanized body capping bjf Defender Technical Discussions 9 July 8th, 2015 04:50 PM
Fitting D110 Body Capping mattarm Defender Technical Discussions 9 July 19th, 2010 07:43 PM
rear 110 body capping WhiteD90 Wanted 10 May 6th, 2008 11:25 AM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
body capping on rear tub WhiteD90 Defender Technical Discussions 5 October 6th, 2004 06:10 PM
