What About Leaking Injectors?? - Defender Source
Old August 7th, 2016, 01:49 PM
RBBailey
RBBailey
1965 IIa
300tdi, at least two of the injectors are leaking. One is enough that the fuel runs down the side of the engine and starts burning off when the engine gets warm.
I believe it is leaking from the actual body of the injector. So a few questions:
  1. Will a shop be able to refurb such an injector?
  2. Can one or two be replaced, or do all need to be replaced at same time?
  3. What tool do I need to remove the injectors?
  4. What else do I need to know?
https://flic.kr/p/KDLtZW
Project:
1965 IIa SWB
Old August 7th, 2016, 03:12 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Originally Posted by RBBailey View Post
300tdi, at least two of the injectors are leaking. One is enough that the fuel runs down the side of the engine and starts burning off when the engine gets warm. I believe it is leaking from the actual body of the injector. So a few questions:[*]Will a shop be able to refurb such an injector?[*]Can one or two be replaced, or do all need to be replaced at same time?[*]What tool do I need to remove the injectors?[*]What else do I need to know? https://flic.kr/p/KDLtZW
If its not the line take them all out and down to diesel fuel injection service on Vancouver Ave. they will test them and tell you if they need to be rebuilt or not. They can rebuild if necessary. Great guys and will get it done right!
Ryan
84 110SW County LHD
07 L322 Vogue
Old August 7th, 2016, 04:37 PM
RBBailey
RBBailey
1965 IIa
That's who I was thinking of going to. Was going to call tomorrow morning.
How do I get injectors out without a specialized puller?
Project:
1965 IIa SWB
Old August 7th, 2016, 05:07 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Ben, you'd better get acquainted with the LR Toolbox video channel.
Lots of good info for Tdi owners...
https://www.youtube.com/user/trailerfitter2
Here's your injectors...
Rent my
Old August 7th, 2016, 06:33 PM
Naplm00
M
I just used a proper sized wrench on the flat area of the injector, being careful to avoid the spill rail sealing spot. Turned it back and forth and lifted hard with the other hand.
I got the old sealing washers out of the bottom with a long long pick
Old August 7th, 2016, 06:40 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
If 1 is leaking then the others are not far behind. Pull them all and @ minimum get them checked.
Old August 7th, 2016, 07:10 PM
Contractor's Avatar
Contractor
Will
1969 IIA
Replace the brass washers at the base of the injectors before you spend a bunch of money. I had two leaking recently as you describe and a couple of new washers fixed me up.
Getting them out was easy, I just pulled them by hand.....if you need to twist, just use a wrench and be very careful of the spill rail surface.
A little bump of compressed air will loosen the offending washers.
Old August 7th, 2016, 07:29 PM
RBBailey
RBBailey
1965 IIa
They are new washers already.
Thanks for the info, all.
Project:
1965 IIa SWB
Leaking injectors? RiftRover Defender Technical Discussions 5 December 17th, 2015 10:51 PM
Injectors Leaking dimcon Defender Technical Discussions 6 March 7th, 2011 05:05 AM
leaking diesel injectors seaswood Defender Technical Discussions 5 July 18th, 2008 06:49 PM
FS Rover V8 injectors ECR For Sale - Parts 0 March 11th, 2008 11:28 AM
fuel injectors not working matt Defender Technical Discussions 1 May 24th, 2007 05:28 PM
» Defender Registry
130
kellymoe
D90
bneri
Add your Defender
