What a blown pressure plate looks like - Defender Source
Old July 26th, 2010, 01:22 PM
I couldn't shift gears without double clutching in the 130 so we took it apart this weekend despite 100 degree temps inside the shop.
Second shot back together.
ID:	29647   Click image for larger version
Name:	130 outside the barn.JPG
Old July 26th, 2010, 01:28 PM
wow. that is impressive. glad you got it sorted.
Old July 26th, 2010, 01:33 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Did you re-gear your t-case too?
Semper Fi!
Old July 26th, 2010, 01:45 PM
Nope- haven't sent Dave Ashcrofft the serial numbers yet to check and see if my stuff will work.
We removed the r380 shift lever,floors,tunnel cover, and the plate under the cubby box, the downpipe off the turbo, and both drive shafts. We then dropped the trans and tcase as one piece complete with linkages in place & rolled it back a foot on the trany jack, installed the new clutch and went right back up with it. A big thanks to Cabell for helping. The clutch disc that was in the truck looked brand new but was a normal 90/110 clutch disc not the 130 part.
Never seen a pressure plate come out in a dozen parts before.
T.O.B wearing groove into pressure plate fingers Noah Defender Technical Discussions 17 October 13th, 2006 12:00 PM
License plate Mike Hippert Misc. Chit-Chat 27 September 16th, 2004 04:07 PM
front plate mounting souza Defender Technical Discussions 10 August 27th, 2004 11:12 AM
pressure plate jperakis Misc. Chit-Chat 1 April 27th, 2004 09:45 AM
