Wet Weather/Won't Start - Page 2 - Defender Source
Old February 4th, 2013, 11:29 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Could also be your idler valve. For the engine to run you need air, spark and gas. I assume that coil/wires/dizzy are new/replaced/ok. You could check for air. When you have the problem, does everything work if you unplug your MAF? If so, this rules out a sensor issue. Clean air filter?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old February 15th, 2013, 05:45 PM
OahuDefender
Jason
1994 D-90
So, the latest update. Took it to a shop and they couldnt figure it out. Thought it was computer related told me to take it to LR. Took it to the dealer. 300 dollars later he replaced the rotor and said it ran fine. Ran fine at first until I got home, turned it off. Next time I cranked it, it fires and catches and then immediately stalls if I'm not on the gas pedal. The only way to keep it running now is by keeping my foot on the accelerator.
It's got spark, fuel and air (tried the MAF sensor and it's not that). It's got a clean filter, new dist cap, new rotor, new wires and plugs. Is it the computer??
Old February 15th, 2013, 06:00 PM
$50-100 for a spare computer it is worth trying to swap.
Old February 15th, 2013, 06:11 PM
Dead ignition amplifier module. See Lav's thread.
start
Wet Engine...No Start the_eaze Defender Technical Discussions 19 January 27th, 2010 10:53 AM
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
