Wet weather no-start - Defender Source
Old October 6th, 2006, 06:38 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Well, it's back.
Honest, I didn't do anything to it. It's been raining here (hood is down), and same symptoms as I had before when I rinsed off the engine. Good fuel, good spark at the coil and at the plugs. I can smell fuel. Once every 20 attempts, it tries to turn over, but just not catching. No ECU codes either. I cranked with the throttle all the way open, and closed.
Any ideas what might be getting wet and where? This is kicking my ass! Fire, fuel, oxygen. I guess it's just not the right combo.
Arg!
Old October 6th, 2006, 06:58 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
I usually WD40 my dist. cap and dry it out. This takes care of the wet day maladies usually.. But if you're getting spark at the plugs and fuel, it is baffling.. Maybe the big connector on the front of the MAF, this used to cause my truck to die at random times.. It was packed with some kind of tan grease which had dried out and the connections were crap.. I picked it all out and cleaned it as best as I could and repacked it with dielectric grease, this solved my issue with random stalling..
let us know what the deal is, we all gain from each others BS rover problems!
Steve
Old October 6th, 2006, 07:10 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
If your ignition switch is going out, it will have that exact same scenario. Have someone check the coil and make sure it is getting the signal from the ignition switch as you are turning it over to make sure the injectors are firing.
Old October 6th, 2006, 07:31 PM
loykd's Avatar
loykd
Ken Loy
How do I do that?
Old October 7th, 2006, 09:17 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
My wet engine/no fire was the coil. When it got wet water would seep into the cap for the high voltage lead out of the coil. I used a little silicone caulking and haven't had any more water problems.
I could hear the short but it was easy to find it at night in a dark garage.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
start
Wet weather and foggy windows, driving in the snow vkv Defender Technical Discussions 25 December 17th, 2009 10:15 AM
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
