'Wet' hub question - Defender Source
Old August 27th, 2007, 04:32 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
'Wet' hub question
For all you guys running wet hubs in the rear how do you know if you have overfilled the diff enough to get oil to the bearings? ( this is on the 110 with a sals.) How do you guys do it?
I'm planning on changing over to wet hubs when I replace my stub axles tonight. If someone has a strong opinion on not removing the seals and keeping the grease please speak up now or forever hold you peace
cheers
Old August 27th, 2007, 07:05 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Just add 3 or 4 ounces, drive it till it warms up good. Left and right turns or sidehills. Park it on a level spot and check it like normal. Add some more if it needs it.
At least that worked on a D 90 rearend with an ARB.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
« Flasher | Waxoyl »
hub bore of a Range Rover P38 or Discovery 2 rvrnut110 Defender Technical Discussions 0 November 18th, 2005 05:26 PM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
another momo hub adapter question dnewman9 Defender Technical Discussions 0 October 3rd, 2004 08:46 PM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
