Wet D90---> won't turn over - Defender Source
Old February 9th, 2016, 10:31 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Hi all. Yes, I searched the forum before posting, but please send links if I missed anything. Also, I'm a rookie, so please be kind.
Anyways, my 1994 NAS D90 got caught in snow/rain/wet the other day with her top off. My dash is apart as I rebuild her, so plenty of exposed wiring. The fuel pump and dash display light up when turning the key, but NO starter movement....nothing. Perhaps a little click (maybe). Bad ground? Any thoughts?
Started up perfectly after she dried out.
I see videos of guys driving through rivers, mine can't even handle a snow storm?
Any advice will be greatly appreciated.
Thanks!
Old February 9th, 2016, 10:45 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
If you have the proper plugs and breather lines for your drivetrain, then fording is fine. I'd bet dollars to donuts you were commoned out with water in your fuse panel or ignition system if the symptoms were resolved by drying out. But I'll defer to the experts.
Old February 10th, 2016, 08:01 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Cool thanks. So are people sealing their fuse panels and ignition systems? Waterproofing them?
Old February 10th, 2016, 08:28 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
take a look at your battery cables if you removed them recently or have added any accessories to the lugs on them. Might be loose (actually sounds like thats the issue to me)
ensure your grounding strap is present/attached to the frame rail well.
Old February 10th, 2016, 09:02 AM
Could be any number of things with your dash off and constantly being fiddled with and then left out in the elements. Put a tarp on it at least dude!
Old February 10th, 2016, 09:56 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
LOL! Yeah, it's back in the garage. I had it outside to tinker with, tarped it, but the wind blew it off overnight. She dry and under a roof now, and will remain there.
Thanks!
------ Follow up post added February 10th, 2016 09:57 AM ------
Thanks! I'll check that out.
Old February 10th, 2016, 12:12 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I haven't sealed mine and I use to drive it in the rain with the roof off.
Jimmy Buffett
Old February 10th, 2016, 12:15 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Coil
Old February 10th, 2016, 12:19 PM
Originally Posted by rd10014 View Post
Coil
His problem is the starter not working....
The OP needs to grab a wiring diagram and fault check the system. There is nothing any web wrenching will do for you.
Old February 10th, 2016, 04:38 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Coil
Brand new coil.
------ Follow up post added February 10th, 2016 04:39 PM ------
Sounds like a plan. I'll find one online. Thanks!
Old February 10th, 2016, 07:52 PM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
Video of her maiden weekend after being parked in a barn for 7 years. Beauty is in the eye of the beholder. http://youtu.be/2O-D0BGuVwg
Old February 10th, 2016, 08:36 PM
chuckc4
chuck b
Registered User
Looking Good!
90, d90
1986 17H Turns Over But Won't Start willhahn24 Defender Technical Discussions 0 September 13th, 2014 11:14 AM
Wet Weather/Won't Start OahuDefender Defender Technical Discussions 23 February 15th, 2013 06:11 PM
Bad/Wet Crankshaft Sensor = Won't start? minch77 Defender Technical Discussions 10 July 10th, 2012 12:22 AM
Won't turn over gtg067i Defender Technical Discussions 6 September 27th, 2009 09:18 PM
Engine turns over but won't start bd90 Defender Technical Discussions 9 August 8th, 2008 12:22 PM
