Welding thin aluminum air condintioning tubing? - Defender Source
Old April 4th, 2009, 10:02 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
On my Disco, there was a wire harness rubbing against my low-pressure side aluminum air conditioning tubing and made a pin hole leak. This is basically right behind the engine and this tube is going to be hell to remove so I was thinking of fixing it in place. Does anyone have any advice on fixing this? Can I solder/braze it? I don't have a tig welder (well I have a Ready Welder that could be a spool gun, but this is a tiny hole in a hard to reach area).
Ideally, if there was some sort of a cold fusion weld or a JB weld that could be used, that would be number one. Number two would be probably using a pencil torch and some aluminum rod if something like that would work.
Any ideas from those with experience on something like this?
Thanks!
Old April 4th, 2009, 10:30 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks!
Hey,
Check out a a product called Devcon Aluminum Putty. It's expensive, about $40, but it will get the job done for you without issue. I may even have some I can send you, but you have to send it back to me! It's a two part kinda like bondo.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 4th, 2009, 07:41 PM
You can also drop by a Thermoking and see if they'll help you out.
Old April 8th, 2009, 09:53 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Buck, that would be AWESOME! I will PM you.
Old January 9th, 2010, 01:29 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Just as a followup, the devcon putty idea worked. I cleaned and lightly sanded the aircon tube, applied the putty and let dry. I have used the air conditioning for almost a year. Very cool stuff.
Old January 9th, 2010, 06:38 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Just to add some more about the Devcon Putty - I bought some to fill in a bunch of holes in my tub from a rear ST seat I took out. Overall it worked great and if I prepped the bigger holes better you wouldn't even noticed that tub was drilled. Expensive but its probably easier and cheaper than finding a good aluminum welder.
aluminum
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
AIR COMPRESSOR Question: norros Misc. Chit-Chat 8 March 21st, 2005 03:28 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
AC to Air compressor Mike Hippert Defender Technical Discussions 5 October 25th, 2003 10:18 AM
