Welding equipment - Defender Source
Old January 24th, 2007, 06:39 PM
paul64's Avatar
paul64
Paul White
Defender 110 CSW 200Tdi
Welding equipment
I have decided at long last to splash out on my own welder. I'm not going cheap either. What brand of welder would you recommend?
Cheers, Paul
Old January 24th, 2007, 07:15 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I have a Millermatic 250X...has always worked well. Will weld 1/2" plate in one pass at 60% duty cycle, I think...if you have an 80 amp breaker.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 24th, 2007, 09:21 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Whats your budget? If you cap it, I can probably recommend a few. Once you get up in the super high price range, I don't know if there is a bad one.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 24th, 2007, 11:25 PM
Nigel
Ted Constantine
I have a miller 210. love it. I would buy the same one again if I had a chance. Second choice would be 251. I have had nothing but good experiences with miller products and I am not easy on them.
Old January 25th, 2007, 12:28 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have the Millermatic 175--it has done me proper and it can also travel well and plug into dryer outlets. To do over again, I would get the Miller 210 or 251 with the tig spool attachment for aluminum. Now that I have been MIG welding a few years, I really want a nice tig set up. And a plasma cutter.
Old January 25th, 2007, 12:59 AM
MattGuyver_007's Avatar
MattGuyver_007
Matt VA
1995 D90 SW
Ditto. Unless you're going to get into some larger gauge steel (over 5/16") I wouldn't go with anything bigger than the 175 or 180. It is light and powerful and can even weld aluminum with the optional spool gun. I love mine and have never wished I bought something bigger or different- plus even an amature can make a weld look like frosting.
Oh, FYI if you plan to weld outside (in the wind) go with a stick welder.
Old January 25th, 2007, 07:21 AM
paul64's Avatar
paul64
Paul White
Thanks Guys that is useful info. I was looking at around 200, which I think is around $380, or there abouts. That would be top end price.
Old January 25th, 2007, 08:08 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Okay,
At that price the very best I think you can do is a factory reconditioned hobart 180 mig. You need to get closer to $800 to get into similar lincoln and Miller.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 25th, 2007, 08:29 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
You might also consider a TIG welder instead of a MIG. Prices have come down and Miller makes some nice ones. Opens up the possibility of doing aluminum welding. Learning curve is longer.
Old January 25th, 2007, 08:40 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
FYI the "spool attachment" is still a MIG gun not TIG
Old January 27th, 2007, 02:27 PM
Cirbo's Avatar
Cirbo
Jim C.
RED!! GO RED!! Ahem... I have a Lincoln 255C, with spool gun attachement. The decision came down to a 12 foot vs. 15 foot MIG gun cable. I've welded with both products, and each are excellent. It's a matter of preference. You won't get either in your price range though.
Old January 27th, 2007, 07:22 PM
paul64's Avatar
paul64
Paul White
How much more expensive would it be? Paul
Old January 27th, 2007, 09:05 PM
Cirbo's Avatar
Cirbo
Jim C.
They were both about ~$1600 to $1700 each. As Rob says though, it will weld just about anything in a single pass though.
Old January 28th, 2007, 08:15 AM
paul64's Avatar
paul64
Paul White
Yes, that is pricey, but as you say if it does a good job, the it will be worth the money.
Old January 28th, 2007, 08:32 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
My cousin has been a welder by trade for years. He has recommended the Lincoln 3200HD that Home Depot sells it is the same unit as the Lincoln 135T just cheaper from the Depot. He uses this welder as his portable around the house welder and is very happy with it. i don't know if this will be helpful or make it more confusing. Good Luck
Eric
Old January 28th, 2007, 08:45 AM
paul64's Avatar
paul64
Paul White
Eric
Thanks for the info Eric, that is useful.
Old January 28th, 2007, 06:31 PM
If all I am interested in doing is fabrication of skids and bumpers etc. on my truck, would one of these 3200HD welders be good enough (if using gas)? It says 5/16 with flux-cored wire, but MIG will be thinner. The 175HD says 1/2 with flux core and 3/16 MIG, but that 230V.
thanks
charles
Old January 28th, 2007, 06:57 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Yes a 3200HD will be fine as long as you run it with gas. It is a great little welder. I have a bunch of series LR customers that I have told about them and they have all been very happy with them.
Eric
Old January 29th, 2007, 11:29 AM
94SW,4.6HSE,93LWB,83 110
Paul64,
I checked out your website. Very cool way to tie together two passions. Best of luck to you.
Old January 29th, 2007, 12:20 PM
paul64's Avatar
paul64
Paul White
Thanks Doug
Original Equipment Land Rover Swing Away Bike/Snowboard/Ski carrier rvrnut110 For Sale - Parts 6 December 6th, 2009 12:31 AM
auto repair shop equipment and car hauler for sale mountainviewrover For Sale - Parts 10 September 17th, 2009 10:36 PM
Largest Tires On Stock Equipment JBOD77 Defender Technical Discussions 13 November 12th, 2007 10:52 AM
Expedition Exchange shawnpalmer Misc. Chit-Chat 155 June 4th, 2007 10:56 AM
welding diff guards rover4x4 Defender Technical Discussions 6 March 26th, 2006 03:50 PM
