Weird turn signal problem - Defender Source
Old December 18th, 2009, 08:27 PM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
1983 110, 1985 110, 1993 110...
Ok my turn signals work, and all the bulbs are good, BUT when I switch on the signal for a right hand turn, I get a fast blinking indication as if a bulb is out. Like I said before, though all the bulbs are good.
Suggestions?
Ohhh also what is the square red light on the back of the vehicle on the right side for.
IPSC_GUY
SIERRA II ALPHA
Old December 18th, 2009, 08:33 PM
The square light is a rear fog light as required in europe. Are you SURE all the bulbs work?
Old December 18th, 2009, 09:14 PM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
Interesting they require and extra "tail light" as it were in Europe? Where are the controls for it located?
Yep I just checked again and both the front and rear turn signal bulbs are good and lighting, albeit at the faster rate like a bulb is out.
Also where are all the fuze boxes on an OLDER 110 located?
IPSC_GUY
SIERRA II ALPHA
Old December 18th, 2009, 09:23 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
It may be a bad connection, or the wrong bulb. Sometimes the bulbs with the gold base trip the system. I would start by making sure you have the silver based bulbs in there. Also, clean up the contacts in the sockets, and the connections where the sockets meet the harness.
Old December 18th, 2009, 09:27 PM
Did you replace any bulbs when this started happening or did it happen spontaneously?
Old December 18th, 2009, 09:31 PM
IPSC_GUY
SIERRA II ALPHA
It is brighter than a normal taillight. Not sure where the switch is as I don't have one. The fuse boxes are under the hood and behind the panel down low in the middle of the bulkhead (the one with the two thumb screws)
Old December 18th, 2009, 09:40 PM
Fog light switch is generally like the main headlight switch but on the other side of the steering column. It probably won't activate unless the headlights are on and please don't use it to improve the visibility of your truck in the rain as it just dazzles the card behind. They have the same brightness bulb as a brake light. I'm amazed that fog lights are not a requirement in this country!
Old December 18th, 2009, 09:54 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Sounds like you may have a set of mismatched bulbs for the flasher unit. Both the bulbs and the older bi-metallic flasher units are sold as either regular or heavy duty. Regular bulbs with an HD flasher causes slow flashing. HD bulbs and a regular flasher cause fast flashing. LED's and old style flashers just don't flash at all.
Newer solid-state flasher units are based on a timer circuit, and don't give a damn about the bulbs.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 18th, 2009, 10:10 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Yeah or the relay is going, just put in a solid state one and save yourself potential headache down the road anyway, had no end of intermittent troubles on the tractor due to two selectively bad relays.
Old December 18th, 2009, 10:36 PM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
-Hans
Give that man a CIGAR ! ! ! mismatched bulbs it is ! ! !
Thant sounds like a heck of idea, who has the solid state unit?
IPSC_GUY
SIERRA II ALPHA
signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
Turn Signal probs mspell Defender Technical Discussions 7 November 5th, 2004 05:19 PM
