Weird surging/power cutoff - Defender Source
Old December 7th, 2010, 11:57 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
A couple of weeks ago the 90 started acting weird. I first noticed it when I pulled from a stop sign and opened it up in the first 2 gears. Then it gave me a surging / hickup. I didn't think too much of it until it was happening a lot during one more short drive. It seems to be happening more frequently.
  • It can be in any gear but mostly when I give it throttle and then let up to control my speed. When I let up and then go to give it more throttle there is nothing there yet it doesn't stall. What I've been doing is depress the clutch and give it a solid hit of throttle. Most of the time it happens when I let up on the throttle but at times it can be when I going to give it more.
  • It idles fine. With the past cold days I've been letting it idle to warm up and then to see if it would stall or act up. But it is fine. I can blip the throttle to wide open and it seems normal.
  • I noticed last night, that when it happened on an open part of road without traffic, I would depress the clutch and keep my foot in the same throttle position. It would dip to about 900 RPMs (normal idle) and after a brief moment the RPM's would pop up to about 3,000 - then drop, then go back, drop, and continue the cycle.
  • I swapped the silver relays with a couple from AB (the black ones), swapped the coil, unplugged the MAF, after reading about the TPS and what it does I thought that "must be it" and bought one from AB. All things I changed one at a time then drove for a day to see what the effect would be.
I'm trying to get it so I can duplicate it at will but haven't gotten to it. But if I drive around enough it seems to eventually happen. What's weird is, I will get a time of normal running - like 10 minutes at a time. On the highway it seems to work fine too.
So - any ideas or any things I should check? I've been STFA under surging and a bad alternator pops up. With it being cold I've been running the fan more lately could that throw it off? What about driving around town and then using the blinker of all things? I have an appointment at the local garage that works on for tomorrow and I'd like to have a better idea of what it might be before I bring it in. Or at least be able to duplicate it at will.
Any help is very appreciated - thanks!
Old December 7th, 2010, 12:56 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Does it come across as a kind of motor boating sound/feel when this happens? If so then you might be having the same problem that happen to my truck earlier this year.
Old December 7th, 2010, 04:29 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
The only time it sounds like a motorboat is when I press in the clutch and keep the throttle at the same position. It revs and lowers and sounds a little like a motorboat prop going in and out of the water. BTW, what was the issue with your rig earlier this year?
Old December 7th, 2010, 08:49 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Can't remember what the idle was like. But I definitely had the 700-3000 jump while driving (and clutch depressed) when the stepper motor died. You can probably check posts from me 4-5 years ago here on this board to confirm.
MonLand
1995 D90 NAS
1996 Discovery NAS
used winch now engine runs weird cpk Defender Technical Discussions 6 March 5th, 2006 04:03 AM
Weird burning smell in 5th gear? oldscratchggf Defender Technical Discussions 7 February 14th, 2006 09:09 AM
Winch Cutoff Switch javelinadave Defender Technical Discussions 24 January 9th, 2005 02:21 PM
weird noise with higher rpm scubadanster Defender Technical Discussions 8 December 13th, 2004 07:32 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
