Weird "Spinning" Noise From Tranny/TCase Area - Defender Source
Old September 8th, 2010, 07:44 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Rebuilt my t-case, now I have a "spinning" noise coming from the tranny/tcase area under the tunnel. It's really hard to explain (and I can email you the sound recording), but it sounds like a bearing race or collar spinning, or if you spin a washer on a bolt. It only happens when the clutch is engaged or on deceleration leading me to the tcase as the culprit. Anyone have any experience with a noise like this?
Semper Fi!
Old September 8th, 2010, 08:16 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
so....
you think there's something spinning in your t-case? ... that can't be right...
Old September 8th, 2010, 08:52 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by bharris View Post
so....
Yeah, I know, it sounded dumb. Nothing is supposed to spin inside a t-case, right?
Semper Fi!
Old September 12th, 2010, 09:18 AM
Wolf Fabrication
Sterling Archer
'08 D3
As a follow up, after tearing down the tcase again it turned out to be the intermediate gear bearings and crush sleeve. The shaft nut was not torqued to specs. According to the rebuild manual the nut should be torqued so that no end play is felt, however, that leads to the issue noted above. Per several rebuild articles in LRM and LRO, the nut should be torqued until slight rolling tension is felt while turning the intermediate gear. I did the second method at that corrected everything.
Semper Fi!
Old September 15th, 2010, 05:06 PM
Wolf Fabrication
Sterling Archer
'08 D3
This follow up should be in reference to the "spinning" noise. This noise ended up being the t-case front output metal dust cup working loose and spinning around the drive shaft intermittently. The clatter is the improper intermediate shaft torque.
Semper Fi!
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
Some weird noise spencer08291985 Defender Technical Discussions 2 February 28th, 2005 03:58 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
weird noise with higher rpm scubadanster Defender Technical Discussions 8 December 13th, 2004 07:32 PM
