weird noise with higher rpm - Defender Source
Old December 12th, 2004, 12:21 PM
scubadanster
daniel park
1997 defender 90
hey all~
on my 97 d-90, SW, i hear a weird sound when at higher RPMs...sounds like coming from the driver side of engine......sounds like something metal rubbing on something??
any suggestions?
it has 82k miles on it...
thanks,
-dan
Old December 13th, 2004, 10:05 AM
what RPMs? Does it sound like it is inside something or on the outside? Is there a rattling to it at all like the sound the cats make when they fall apart?
Old December 13th, 2004, 12:44 PM
scubadanster
daniel park
1997 defender 90
oh ya!
that sounds right......could be that.....
when the rpm hits >4-5k.....like going uphill......it rattles....sounds like tin rattling....like the cats....how can i be sure??
thanks, my bro....
-dan
ps> could that be why my SERVICE ENGINE light is on??
Old December 13th, 2004, 01:00 PM
Yep that may be why the light is on. I would check the ECU code I bet it has something to do with your cats. You develop the most exhaust pressure and flow when high in and the engine is under a load, so thats why you only hear it on the highway uphill high in RPM.
Old December 13th, 2004, 01:28 PM
scubadanster
daniel park
1997 defender 90
mike!
you are the man...
will this be costly to fix? good time to upgrade??
thanks!
-dan
ps> would this fail my smog check too??
thanks again!
Old December 13th, 2004, 01:45 PM
Cats are $$$ at the dealer, not sure how much, mine are both dead but we don't have smog checks so I leave them as is for now. And I am pretty sure that you will fail your smog check if they are bad. But you could do this
http://www.defendersource.com/faq/En...haust.html#Cat
Old December 13th, 2004, 02:23 PM
scubadanster
daniel park
1997 defender 90
thanks again, mike!
-dan
Old December 13th, 2004, 07:26 PM
scubadanster
daniel park
1997 defender 90
is it worth a full exhaust system??
anyone know?
thanks,
-dan
Old December 13th, 2004, 07:32 PM
Not unless you really need one (like it is rusting apart), or you want a better sounding system. If it is just sound then get a Flowmaster, for an upgrade go stainless, Borla makes a system but it is only cat back and it costs in the $400 to $500 range.
97 D-90 Auto Transmission Shifting at Higher RPM parkcity4x4classic Defender Technical Discussions 7 October 30th, 2006 05:35 PM
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
Some weird noise spencer08291985 Defender Technical Discussions 2 February 28th, 2005 03:58 PM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
