Weird noise/shitter when turning left. - Defender Source
Old January 25th, 2015, 11:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
Got a friend (clearly a lie) with a 110. When he turns left/not full lock and not every time he gets this weird shutter. At first I thought it was the brake shield but I don't think it's that. Coming from front I think. Others think under neath.
Any ideas?
Old January 25th, 2015, 11:52 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
CV or hub. Just guessing since I've been spared such issues. Got to start somewhere.
Got to admit the title through me with "shitter". You're bound to catch some flack.
Black Rhino Lives Matter
Old January 26th, 2015, 12:00 AM
bjf's Avatar
bjf
barry f
94 ST #395
Shutter/shitter all the same
Old January 26th, 2015, 01:03 AM
87 D110 (Ruby)
Cv...clacking noise = CV
Old January 26th, 2015, 01:09 AM
Ignotus
gene
1960 109, w/200TDI
"Shutter/shitter all the same" really probably means shudder.....
Gene
1960 109
1960 88 Ignotus
Blog;
Old January 26th, 2015, 01:25 AM
bjf's Avatar
bjf
barry f
94 ST #395
Describe clacking
Old January 26th, 2015, 01:31 AM
Originally Posted by bjf View Post
Describe clacking
CV tends to be more a loud pronounced clicking...did not sound like what you described in our phone call.
Old January 26th, 2015, 02:52 AM
If you turn the wheel no brakes does it happen? Now turn the wheel with brakes does it happen?
Lift front axle off ground. Both sides. Engage gear (center diff unlocked). Test.
Old January 26th, 2015, 10:00 AM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by Rocky View Post
If you turn the wheel no brakes does it happen? Now turn the wheel with brakes does it happen? Lift front axle off ground. Both sides. Engage gear (center diff unlocked). Test.
What are you thinking it is?
Old January 26th, 2015, 10:20 AM
Tire hitting chassis?
Old January 26th, 2015, 10:21 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Brake caliper loose?
Old January 26th, 2015, 10:28 AM
bjf's Avatar
bjf
barry f
94 ST #395
Tires aren't hitting but I thought that. Brakes are tight.
Old January 26th, 2015, 10:47 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
Define shudder. Do you feel it in the seat? In the steering wheel? Is there a noise? You have provided us practically zero information.
Old January 26th, 2015, 10:50 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Any clunk? Swivel bearing (upper) may be worn/separated.
Old January 26th, 2015, 12:09 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
My failed CV didn't make a loud clacking. I did get the odd binding when turning though
Jimmy Buffett
Old January 26th, 2015, 12:15 PM
Yours probably broke.
The clacking comes from a worn CV joint, not a broken one. Worn ones tend to originate from loss of lube or contaminated lube.
As to Barry's problem, it could be a lot of things and you really need to get it on stands and look at everything.
Old January 26th, 2015, 12:33 PM
bjf's Avatar
bjf
barry f
94 ST #395
I like giving no information and having everyone guess.
I will ask about CV joints.
Old January 26th, 2015, 01:13 PM
My point is that it would be best to investigate other causes as much as possible first especially when paying someone to fix it. To open the axle and look at a CV, you'll be charged 3 to 4 hours labour and when you suggest it, you are pretty much giving them permission to dig right in.... It could be a lot of things.
Really doubtful that you have a worn CV unless the swivel seal is completely gone and the swivel is full of dirt. Being that you don't go off road, I would doubt it.
Scraping noise when I turn left bjf Defender Technical Discussions 8 July 30th, 2014 02:09 PM
Grinding/weird noise 94 Defender NAS triple9music Defender Technical Discussions 10 July 13th, 2012 12:45 AM
Weird "Spinning" Noise From Tranny/TCase Area Wolf Fabrication Defender Technical Discussions 4 September 15th, 2010 05:06 PM
Some weird noise spencer08291985 Defender Technical Discussions 2 February 28th, 2005 03:58 PM
weird noise with higher rpm scubadanster Defender Technical Discussions 8 December 13th, 2004 07:32 PM
