Weird issues in reverse... - Defender Source
Old October 17th, 2016, 12:00 AM
spaeth's Avatar
spaeth
Craig Spaeth
93 RRC LWB 300TDI
I have a 93 RRC with a LT230, automatic transmission and TruTrac limited slip diffs in both front and rear. When backing up there is a real notchiness to how the rig moves in reverse. There is no feeling of this when moving forward only in reverse. Seems to be worse when backing up hill vs downhill or flat. The transmission was gone through when I first got the truck. Just trying to narrow down where to start with this.
Thanks in advance for any ideas.
Old October 17th, 2016, 12:12 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
FYI-- not that it matters for your symptoms, but the LT230 is a transfer case...
Old October 17th, 2016, 12:14 AM
spaeth's Avatar
spaeth
Craig Spaeth
93 RRC LWB 300TDI
I guess that was a critical comma to leave out. Thanks for the clarification though.
Old October 17th, 2016, 12:20 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
"I'm starving. Let's eat grandma."
"I'm starving. Let's eat, grandma."
See. Proper punctuation saves lives!
But back on topic; does it chirp and feel like it's locked backing up?
"Barry is correct!"
Old October 17th, 2016, 12:43 AM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Originally Posted by D90Overkill View Post
"I'm starving. Let's eat grandma." "I'm starving. Let's eat, grandma." See. Proper punctuation saves lives! But back on topic; do you feel like it's locked backing up?
Omg. I'm laughing so hard I'm crying.
Black Rhino Lives Matter
Old October 17th, 2016, 12:47 AM
D90Overkill
David Frank
1995 ST #2615
Hehe! ;-)
"Barry is correct!"
Old October 17th, 2016, 04:57 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
What fluid are you running in the diffs ? Tru tracks do not do well with synthetic and cause chattering and binding
Sent from my SM-G920P using Tapatalk
No Mall crawler here
Old October 17th, 2016, 09:11 AM
spaeth's Avatar
spaeth
Craig Spaeth
93 RRC LWB 300TDI
It does feel like it is trying to lock up. Not quite chirping but getting close to that. Running a 90 weight gear oil. I did have synthetic in there for a short time but that was over a year ago and the. I read about the limited slip diffs preferring regular gear oil.
Old October 17th, 2016, 10:25 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
It does it all the time or just after wheeling it ?
Every once in a while my t box gets wound up and takes a few times to release
Old October 17th, 2016, 11:10 AM
Does the steering have higher resistance to movement when this happens?
What happens if you shift the Transmission into neutral, allow the car to roll a a reasonable unlocking distance then engage R again? Does this notchiness return?
Old October 17th, 2016, 12:11 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Grandma Donner?
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old October 17th, 2016, 12:15 PM
I personally would start by removing the front driveshaft and seeing if the feeling goes away in reverse
Just a suggestion
Old October 17th, 2016, 12:40 PM
spaeth's Avatar
spaeth
Craig Spaeth
93 RRC LWB 300TDI
Does every time in reverse. No difference in steering feel. No feeling going forward, feels completely normal forward. It does seem to catch more some times than others but you can always feel it a little bit.
I will try pulling the front shaft and see what that does. Was hoping maybe someone would have a quick answer here, but that isn't too tough to tackle.
thanks
Old October 18th, 2016, 01:34 PM
I would suspect that the TrueTrac is damaged. When you drive the "side gears" either thrust inwards or outwards quite strongly. They are assembled in a way that in forward the thrust is inwards and in reverse the thrust outwards. Unfortunately, in order to same two dollars in the manufacturing, they use a thrust bearing only in the center. On the outside the side gears thrust steel on steel. I suspect there is damage to the outer thrust faces and it is causing the "pinion gear" to lock up and prevent differential action or, at least, making it notchy. When you go forward the thrust is into a proper thrust bearing and there is not problem.
You will need to pull drive flanges to see which axle and then pull that diff out.
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
Weird burning smell in 5th gear? oldscratchggf Defender Technical Discussions 7 February 14th, 2006 09:09 AM
Some weird noise spencer08291985 Defender Technical Discussions 2 February 28th, 2005 03:58 PM
weird noise with higher rpm scubadanster Defender Technical Discussions 8 December 13th, 2004 07:32 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
