Weird Indicator Fault - Defender Source
Old October 28th, 2014, 01:42 PM
Hache
Henry Lambert
1983 Ex-MOD 90 2.5N/A
On my ex-mod 90 my indicators/turn signals are behaving strangely.
The front right signal and repeater aren't working at all.
So when turning right, only the rear right signals flash. If I have the sidelights illuminated then the right sidelight flashes too (which is odd but suggests a bad earth I think).
When turning left, the two rear (right AND left) and front left signal and repeater flash.
I've checked the front two earthing points inside the wing and they look ok - no corrosion of dirt build up.
Tried replacing the flasher unit.
Also tested the repeater bulbs.
One of the rear fogs is missing a bulb but didn't think they'd be on the same circuit.
Any help greatly appreciated.
Thanks.
Old October 28th, 2014, 01:56 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Encountered a similar problem, but not exactly the same on a 1984 110.
To fix it had to replace the fuse box and hazard warning switch and hazard flasher.
RDavisinVA
Old October 28th, 2014, 02:26 PM
Hache
Henry Lambert
Do you know what the exact cause of the problem was?
Old October 28th, 2014, 02:43 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Before you do anything else, make sure all bulbs work and are secure in their sockets
Old October 28th, 2014, 03:19 PM
Hache
Henry Lambert
All the bulbs except one of the rear fog lights work but I bridged the circuit there.
What's also odd is that I was driving the other day and the indicators started working normally again. Then on my next trip they were back to their old tricks.
Old October 28th, 2014, 03:26 PM
rankar's Avatar
rankar
Disconnect your hazard switch, clean contacts on switch and harness, reconnect then try again
Old October 28th, 2014, 03:34 PM
Check all the ground connections first. Check the integrity of all the bullet connectors by pulling on all the wires. They come loose.
Old October 28th, 2014, 04:13 PM
Hache
Henry Lambert
Great. I'll try both hazards and connectors.
Weird Indicator Fault Hache Series Technical Discussions 0 October 27th, 2014 05:28 PM
Indicator fault Peachy Support & Suggestions 4 October 22nd, 2013 02:20 PM
DX Indicator on Radio tron Defender Technical Discussions 5 April 20th, 2005 04:34 PM
Dash Indicator? DJ Menasco Defender Technical Discussions 9 September 11th, 2004 04:07 PM
indicator's rover4x4 Defender Technical Discussions 0 October 27th, 2003 03:02 PM
