Weird fuel leak - Defender Source
Old March 14th, 2012, 09:38 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Weird fuel leak
Didn't want to hijack the other fuel tank thread, but i have the same tank, which I thought was leaking, but now I am thinking its leaking somewhere else and running down the to the bottom of the tank.
It is sporadic and seems to leak worst when the engine is under load, like when taking off from a stop.
Any ideas?
Old March 14th, 2012, 10:07 AM
Tom, do you have the ROW rear fuel tank, NAS rear fuel tank, or the old-style under-seat fuel tank?
Old March 14th, 2012, 12:16 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Under passenger seat
Old March 14th, 2012, 12:24 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Split fuel line? Fitting not tight enough?
Old March 14th, 2012, 12:34 PM
The design of the fuel tank is somewhat interesting.
There is a skid, and the skid is welded via spot welds to the tank. The tank skid is what is attached to the frame. You already know this much I'm sure
If you drill out the spot welds and separate the skid from the tank, then you will see that there is some kind of rubber and foam mastic between the fuel tank and the skid. This stuff traps moisture and will cause both the skid and fuel tank to corrode and rust.
There are several ports on the fuel tank. The first is the main fill port, located at the rear of the tank. Above that is the relief port. Both the relief port and the main fill port should be connected via fuel line to the fuel filler neck. The intent of the relief port is double. The first is to allow air to escape the tank while filling. The second is to start flowing fuel into the top of the fuel filler neck in order to signal the user that the tank is full.
The top of the tank has two ports. The first is the port for the fuel pickup/fuel sender assembly. The second is the return line port.
If you have a leak that gets worse when you accelerate, I would first check the connection of the fuel filler line to the main fill port and the connection of the fuel filler line to the relief port. These are to the rear of the truck and therefore would experience leaks as the fuel shifts to the rear of the tank during acceleration.
fuel
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
