Weird burning smell in 5th gear? - Defender Source
Old February 11th, 2006, 06:59 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
While driving 65+ on the freeway in 5th gear, there is a speradic burning smell. It is only while I am in 5th gear, and I have not noticed any patterns of any sort. It doesn`t smell like burning oil or plastic.... I can`t really tell what it smells like. Maybe some sort of burning rubber? I have no clue, and I can`t locate it because it only happens while I`m on the freeway and going 65-70 miles an hour. Anyone else ever experienced this with their trucks? Anyone have any clue what it could be?
Old February 12th, 2006, 09:46 AM
Look around the exhaust , there might be a wire blowing upp against it when on the freeway that is slowly meltig.
Old February 13th, 2006, 03:10 PM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
also check your axle breathers, I had that one happen to me
Old February 13th, 2006, 03:51 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Mine will smell like that when I need to downshift, like it's running real rich. I figured it was the exhaust coming back in the ST
"It's not a Jeep"
Old February 13th, 2006, 06:21 PM
oldscratchggf
nate
95 d90
I had already checked for wires blowing up against the exhaust, and I did in fact have a couple, so I took care of that, but the smell continued... I guess i`ll try the axle breathers now... Thanks for the suggestion
Old February 13th, 2006, 07:39 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Humm, clutch slip? The resistance of the drive line is greatest in highest gear -- when you gas it going uphll in 5th, maybe the clutch is slipping?
DW
Old February 14th, 2006, 04:30 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
ALso it could be hot grease or gear oil getting flung onto exhasut from the propshaft
Old February 14th, 2006, 09:09 AM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
I had my ignition coil go recently and it smelled like burning plastic/rubber.
(only thing not mentioned that I can think of).
Could be oil gear or engine splattering on the manifold or exhaust.
Could also be oil from axel getting on hot brake rotor (through seals) look to see if one of your brakes is real goopy looking.
Could be clutch (is it slipping at all)?
Also check the parking brake cable, which likes to touch the exhaust on my rig.
Hope this helps.
-Heath
95 D-90 5th gear broken DG Rodgers Defender Technical Discussions 4 February 19th, 2009 10:06 AM
5th Gear Issues bdthornton7 Defender Technical Discussions 0 August 17th, 2008 03:33 PM
5th gear and Reverse sticking anthony Defender Technical Discussions 2 May 22nd, 2007 12:09 AM
Question about burning smell michael15 Defender Technical Discussions 13 March 7th, 2006 01:30 PM
