weird brake lights - Defender Source
Old April 16th, 2006, 08:41 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
weird brake lights
Got a problem with my brake lights I cannot explain. When the LIghts are off, my passenger side brake light does not come on but the driver does. WHen the lights are on, the passenger does nothing and the driver side turns off. If the brake pedal is not depressed both lights are on just fine. The third brake light is fine. Any ideas?
Old April 16th, 2006, 09:19 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I'd get a buddy to come over, get in there with a test light, and see if everything is wired correctly. the harness comes up on the passenger side, behind the speaker, and there are some connections in there that may have gotten screwed up somehow.
Where in NY are you anyways?
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 16th, 2006, 09:24 PM
Yeah, my dash lights are wierding out too when the headlights are on - at first they only came on when i depressed the brake pedal, now they dont come on at all. There is also taillight involvement. And I'm using a completely different non-nas harness that is only a year old. I'm pretty sure its a simple ground fault since electrical gremlins are most often caused by a bad ground. I just havent had the time to troubleshoot it yet - but I'd love to hear what it was if you get it solved first!
Old April 17th, 2006, 02:22 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I am in Nyack, Ny right by the tappan Zee bridge. I'll check the harness on the passenger side and see what's up. I looked in the wheel well and all the wires coming out of the taillights are hanging right there. Seems like a silly design given all the mud, road debris, water and other crap that spins off the wheels.
Old April 17th, 2006, 11:37 PM
Scott 9835
Scott Falter
95 D90
Change the bulbs. Sounds like the brake lights and running lights filments broke and is touching each other. So when the lights are on, they work ok, but when you hit the brakes the bulb backfeeds shutting the light off. I have seen it before. Hope this helps.
brake, ht, lights
No brake lights! Need help. durangorover Defender Technical Discussions 10 September 30th, 2011 11:18 PM
Weird brake light issue on my 97 Please HELP! Cyborg Defender Technical Discussions 8 July 12th, 2009 01:04 PM
Help!!! State Inspection No brake lights !! Hammertime Defender Technical Discussions 11 February 10th, 2008 08:09 PM
Brake Lights Stuck ON RoverWrecks Defender Technical Discussions 4 August 21st, 2004 11:26 AM
