Weird brake light issue on my 97 Please HELP! - Defender Source
Old July 11th, 2009, 07:04 PM
Cyborg
Larry Walton
'97 D-90 ST #2066 UK 4X4
So I had people tell me that my two of my brake lights were not working. I tested and discovered that my third (high mounted) brake light was the only one working. No big deal I assumed it was bulbs or sockets.
I found a bad socket on the drivers side. I replaced it and got my tail light working on that side but the brake lights still were not working.
I dug deeper and discovered the following.
The tail light filaments in these bulbs light with the headlights just fine. So I know the ground to each socket is good.
The center brake light turns on so I know the brake light switch connected with the brake pedal is working and power is getting to that one brake light..
With my shovel holding down my brake pedal I am not getting any voltage at either of the connectors which connect to the back of my sockets on the driver or passenger sides when voltage is read in reference to the known good ground on each connector.(Remember the tail lights use these gnds so we know they are good)
At this point I am believing that the problem is in the wiring for the power. Based on the diagrams I have here it seems that it MUST be a bad connection at the A3/A4 harness splices (Upper left side of page 29/43.1 Exterior lamps, Brake and Reverse lamps)
So my questions for you guys are....
Can i trust these diagrams?
Could the problem be something else?
If it is likely a bad connection at the A3/A4 splices does anyone know physically where they would be located? Under my vehicle the wires from each side seem to converge near the gas tank under above the protective armor. The splice seems likely to be located there but I would hate to rip all of that out just to find out it is someplace more conveniently located.
Any advice would be appreciated.
Visit the Land Rover Beer Bar,"The Best Beer Bar X Far!"
Old July 11th, 2009, 09:08 PM
Cyborg
Larry Walton
Does anyone know how the wiring from the brake switch to the brake lights is routed? The signal is getting to my third brake light only so I suspect the problem is where the wire is spliced to diverge from one wire to three going to the separate brake lights. Does anyone know where that point is located? I am on the verge of dropping my gas tank because I SUSPECT it may be under there. Geez I dont want to do that especially if it is unnecessary.
Old July 11th, 2009, 10:55 PM
specops1526's Avatar
specops1526
Beluga '97 90
Don't know much about the wiring but I know that the connectors on the round tailights had issues of corrosion which LR tried to remedy with a rubber boot kit, especially for trucks in wet environments. Have you checked those?
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old July 11th, 2009, 11:05 PM
SPIKE's Avatar
SPIKE
Eric
94 D90 #1
Red face Don't drop the tank.
It's been awhile since I've had a 97 but I bet that they are behind the passenger rear speaker as on earlier models.
Old July 11th, 2009, 11:24 PM
This is right.
Old July 12th, 2009, 12:05 AM
Cyborg
Larry Walton
specops, I have been all over these connectors. I have the rubber boots installed and I cannot see how the connectors could be at fault. They look fine. I will double check the brake light leads to be sure.
PIKE and evilfij,
Yes there are some odd wires behind the speaker box on the back deck on the passenger side. Mostly loose wires not connected into anything other than the wires for the 3rd brake light. I will see about possibilities there. Maybe something got unplugged? What I saw didn't look like that was a possibility. I am tired and will look in the AM.
THX for the input.
Old July 12th, 2009, 07:47 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Just get a voltmeter, start at the rear right side tail lights(the left side wires come across and join on the right side rear) and work yourself forward. You need to test every connection. Check ground wires also. Third brake light comes off in the rear, so the problem is in that area.
Old July 12th, 2009, 12:07 PM
Cyborg
Larry Walton
Hoosier,
Thanks for the input. I have been using my meter it is just that I have been reluctant to start stripping away the harness wrap until I have a better idea where the splices may be. It sounds like you may be suggesting that the split takes place on the right rear. I hope so as I am concerned since the harness goes into the covered area of the gas tank.
I will strip the harness open in the right rear area and figure it out.
Old July 12th, 2009, 01:04 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
The junction you seek should be behind the RR speaker. Green/Purple is brake lights, I think. The main harnass goes up behind the speaker. The wires terminate in big junctions. There is a subharnass that goes across the rear crossmember that feeds the left side and another that feeds the right side. The trailer wiring subharnass and third brake lights are fed from this junction. You obviously have power to that point if the third brake lights work.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
97, brake, ht
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
