Weezing Sound - Defender Source
Old March 2nd, 2010, 09:38 PM
merlin8ty's Avatar
merlin8ty
Cliff Weinstein
1997 D-90 AA Yellow
Weezing Sound
Any thoughts on a weezing sound when i accelerate? Weezing is the best word i can think of. Its a high pitched weezing sound that correlates to the pressure of the gas pedal. Its not very loud and its not there all the time. It sounds like it coming from directly underneath the glovebox/automatic shifter.
Old March 3rd, 2010, 12:08 AM
CDeWan
Clay DeWan
5.3L beastie
vacuum leak most likely, while the car is running (but be very careful and have a fire extinguisher around just in case) spray either starter fluid or brake cleaner around the intake, vacuum lines and see if the RPMs change. Don't spay on the exhaust. Also do you have air conditioning? As the air cleaner is above the tranny, you may just be hearing the air going into the air cleaner and/or you may have a few rubber grommets, seals out of wack that are allowing that noise to be picked up in the cab.
does this sound like a rover V8 rover4x4 Misc. Chit-Chat 4 January 5th, 2006 06:24 PM
Sound Dampening Material kellymoe Misc. Chit-Chat 1 March 13th, 2005 01:34 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
