Weep Holes? - Defender Source
Old June 17th, 2004, 10:15 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Weep Holes?
I am changing my Headlights this weekend. I have a quick question. Should I drill a small weep hole in the fron running lights? I have heard that you can sometimes fry your ECM if your rear tail lights fill and short. Does this hold true for the front as well?
TIA,
Old June 17th, 2004, 10:26 AM
Fry your ECM from your lights???????????????? Thatís a new one, itís possible if a lightning bolt hits your tail lamp that it would kill your ECM but no weep hole is going to help with that. I wouldn't worry about it to much; I would be more worried that your ECM is in a dry place if youíre in water up to your headlamps. The most damage your headlamps in water could do is short out a fuse. Oh and after your headlamps have filled with water it takes 3 days before they dry out again.
Old June 17th, 2004, 10:34 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
The weep holes are on the EE site. I haven't done them yet, but was thinking of it. Apperently someone serious messed up their ECM and the diagnosis was water in the tail lights caused a short which caused the failure. It seems far fetched, but an ounce of prevention so they say.
EwS
Old June 17th, 2004, 10:43 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I don't know how you would fry your ECM by doing so. The lights don't run directly through the ECM. Believe me, I know. I've permanently removed my ECM and my lights function as they did before. Shorting them would blow the fuse and maybe the relay, as designed.
You also might be better served by installing the military light boot kit. silicons rubber boots over the light harnesses.
Old June 17th, 2004, 11:13 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Boot kit installed. Cool. Sounds like another internet myth. I always seem to fall for them. Yet again, thanks D-90.
EwS
Old June 17th, 2004, 09:09 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I take it Mike the water finaly drained out of your lights?
Jimmy Buffett
Old June 17th, 2004, 09:20 PM
yep
Rover Rust hole, not mine, nor do I know the owner. But if you need one. rgrrvr The Flea Market 6 May 28th, 2008 10:52 PM
Dilling holes in aluminum body panels fenwaystan Defender Technical Discussions 1 March 22nd, 2008 01:14 PM
Holes in body kennybahr Defender Technical Discussions 23 January 22nd, 2008 07:23 PM
Sealing Rear Wheel Well Bolt Holes Boone90 Defender Technical Discussions 10 February 18th, 2007 01:30 PM
Drilling holes for rear light guards khatadin Defender Technical Discussions 8 January 5th, 2005 08:43 PM
