Webasto troubleshooting - Defender Source
Old February 4th, 2016, 10:58 AM
edfest
Ed Mistler
88 D-110 station wagon 2.5TD
My Webasto stopped working
It was working fine, then I had the timing and fan belts replaced, and now the webasto shuts off after a minute or two.
The fan comes on, the circulating pump starts, a puff of exhaust comes out, the fuel pump starts clicking in the back. Then the fuel pump shuts off and the fan goes through the shut down cycle.
All in about 2-3 minutes.
There doesn't seem to be any problem with the coolant level (no gurgling/bubbles, etc).
The air intake and exhaust are both clear.
The only thing I've noticed, is there are small bubbles in the fuel line that seem to clear as the fuel pump gets up to speed. I'm not sure if that is normal? and I don't know if the bubbles could cause a flame out, causing the system to shut down? and where would the bubbles come from/how can I bleed them out?
Any help would be appreciated!
Thanks!
I have a Webasto thermo top E on a 2.5TD.
-Ed
Old February 4th, 2016, 11:07 AM
Make sure there are no leaks in the fuel lines. Any air can cause a flame out during start-up. Replace the fuel filter. When they get clogged, the units won't start up. Most likely one or the other. If it is something else, you either need to take it apart and test each part to connect to a computer and check for error codes.
Old February 4th, 2016, 11:22 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
One condition you could be experiencing is a bubble in coolant lines, causing the circulating pump to bind, or pump air. With no coolant flow through the unit, it rapidly comes up to temp then shuts itself down because it thinks that it has done its job.
One way to bench test it while still installed is to take off the inlet line to the circulating pump and use a piece of old hose with a 2 liter soda bottle attached to it (with the bottom cut off - giant funnel). Next take off the hose before it goes back into the engine and direct this to a 5 gallon bucket. Raise the giant funnel to the windscreen, bungee it to your door/roof rack/roll bar and fill it. Fire up the webasto and see if it sucks the funnel down. Be ready to fill it as it pumps down relatively quickly. If you have a small bucket, you can take the water coming from the outlet and pour it back into your homemade funnel. Best done with a helper who can film you as you try to keep the funnel full of water before it goes low out of sight, or simply helps fill the funnel.
Who needs a webasto with the winter we're having though!?
Old February 4th, 2016, 11:48 AM
He is not describing a lack of coolant shut down. It is a flame failure during startup.
Old February 4th, 2016, 04:55 PM
edfest
Ed Mistler
Thank you for the tips!
I've read about fuel filters with the webasto, but I assumed I didn't have one.
What do they look like?
My fuel line/pump appears to come right off the tank... But then the line gets lost and covered by copious waxoil (as does the actual pump).
I'm also leaning toward a fuel delivery problem, or flame issue.
I considered a bubble in the coolant system, and I still haven't eliminated it.
I will have to try the pump test.
And the only reason I need the webasto, is it significantly decreases the amount of smoke I generate on startup! Which decreases the number of glares I get from hipsters and bicyclists
Old February 4th, 2016, 05:29 PM
scrubs
henery
1974
Sometimes this happens with mine n always turns out to be low battery.
Old February 4th, 2016, 05:32 PM
If it does not have a fuel filter, you will have a lot more problems than you want. It is a small inline filter.
That is true that if the voltage drops too low, it will cut out.
Old March 14th, 2016, 10:07 PM
edfest
Ed Mistler
Update:
It was the webasto fuel pump. It was making lots of noise, but apparently pumping fuel inconsistently. The new pump is quiet, and consistent. Just in time for summer!
(unfortunately, now the engine doesn't start but I suspect a bad wire leading to the solenoid... at least, I hope its a bad wire leading to the solenoid)
Thanks to everyone for the help!
webasto
Webasto ThermoTop C and Webasto Fuel Pump flananuts For Sale - Parts 4 October 7th, 2015 09:08 AM
Electrical troubleshooting advice cbass Defender Technical Discussions 7 January 12th, 2011 08:13 AM
A/C troubleshooting help Sought... LRNAD90 Defender Technical Discussions 3 August 28th, 2008 09:46 AM
Reverse light troubleshooting loykd Defender Technical Discussions 4 August 23rd, 2006 12:56 PM
Front suspension troubleshooting... sflash868 Defender Technical Discussions 1 June 5th, 2006 07:22 AM
