Webasto Thermo Top overhaul help needed - Defender Source
Old February 7th, 2015, 04:39 PM
Question Webasto Thermo Top overhaul help needed
I have a C/Z diesel unit. I've pulled it to put a new glow plug in it and decarbonize the burner, since it's was spotty starting in below freezing temps. I have it on the bench, and although I found very little carbon, I was expecting a burner screen (steel wool mesh) inside the burner chamber that I've heard so much about being careful with, only to find there wasn't one there at all.
Has anyone else had their Thermo Top C apart and seen the metal mesh in there, or was yours lacking one as well? The parts manual has no reference to internal burner parts.
I can see a burner screen available from china (of course) for the C/Z on ebay. nobody else stocks just that part that I can find.
Mark Kellgren
KM4BOR
Old February 8th, 2015, 10:01 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
I pulled apart and refreshed two c/z diesels that came right off Freelanders in the UK and neither of them I believed had a steel wool mesh in them.
Old February 8th, 2015, 10:16 AM
No idea. But if you have spotty starting when cold it is most likely the fuel filter plugging. They gel easily. Make sure the filter is new and you are using an anti gel.
Old February 8th, 2015, 10:24 AM
ok thanks all!
Mark Kellgren
KM4BOR
top, webasto
Planning to buy a few webasto thermo top c's for the Freelander out of the UK flananuts Defender Technical Discussions 16 January 25th, 2014 07:48 AM
Webasto Thermo 50 tjfslaughter For Sale - Parts 6 November 8th, 2013 03:02 PM
Webasto Thermo Top C TSL17 tjfslaughter For Sale - Parts 9 August 10th, 2013 06:17 PM
Help With Part ID - Thermo Housing/Coolant Temp Sensor? geoellis Defender Technical Discussions 13 April 2nd, 2013 10:24 AM
webasto thermo top vlocci For Sale - Parts 3 May 3rd, 2011 12:31 PM
» Defender Registry
Chapolin
aprellvitz
Max
juddy
Add your Defender
