Webasto Install Location - Page 3 - Defender Source
Old January 19th, 2015, 01:47 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Well, there you go. Thanks John.
Old January 19th, 2015, 01:49 PM
Just keep in mind the fuel pumps put out a lot of pressure, so make sure the piping is able to handle it.
Old January 22nd, 2015, 11:38 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
How much pressure? Apparently a selection of Goodyears Fluoroelastomer fuel injection hoses are B100 resistant and rated to 100 PSI. Would that be enough?
Old January 22nd, 2015, 11:46 AM
I had a brief look and I can't see anywhere that Webasto states the pump pressure. On other larger units they state 150 psi. Why not just use the normal tubing that comes with the heaters? I assume it is nylon, which is BD compatible, is very low cost and will happily do 1000 psi.
Old January 22nd, 2015, 11:48 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My kit was put together by a forum member and it it had a Nitrile fuel line which is not B100 compatible. I'm thinking about going with the Gates Barricade. Do you think that would would be a good candidate?
webasto
Webasto 2000 Install Jbullis Smaller Projects 7 January 21st, 2014 10:15 AM
Webasto 2000 install question 110 dcpu gomotomoto Defender Technical Discussions 7 December 11th, 2013 04:57 AM
Webasto Gas Heater Install - where should I put it RedD90 Misc. Chit-Chat 14 February 17th, 2012 09:42 PM
Webasto Air Heater Install ideas... tjfslaughter Defender Technical Discussions 10 October 28th, 2011 12:51 PM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
