Weakness of a D90 - Page 5 - Defender Source
Old November 20th, 2014, 11:31 AM
Grover's Avatar
Grover
Originally Posted by petminded View Post
As for the relays, I see Rover's North had two different parts. One for multiple applications, and then the fuel pump.
Pump:
http://www.roverparts.com/Parts/AFU2913OE
Other:
http://www.roverparts.com/Parts/YWB10027L
So do I want two of the multi and one for the pump, or are you saying that they are really the same and just to get two of which ever?
Hmm, I can't remember. I'll check tonight...
Old November 20th, 2014, 12:01 PM
The fuel pump relay is rated for 30 amps. The other general purpose relays are all 15 amp. There are two kinds of the general purpose; yellow and green. Yellow is 5 leg and green is 4 leg. Yellow is a dual throw "this or that" relay and green is a single throw "on-off".
Mouser Electronics has the fuel pump relays for about $3.00. Item # 655-1432772-1
Old November 20th, 2014, 01:53 PM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
I've called 3 places and all three have something different to say. One place says the fuel relay is 50 amps. Another place says they have a 4 plug (their yellow) and 5 plug (their green) relay but both are rated for 30 amps. And the last place has a 4 plug 'yellow' and a 4 plug 'blue' relay. Go figure.
So now I'm lost. Any suggestions?
Old November 20th, 2014, 02:13 PM
your owners manual?
Old November 20th, 2014, 02:53 PM
petminded's Avatar
petminded
David
Originally Posted by rijosho View Post
your owners manual?
I'm flattered that you think I can read.
Old November 24th, 2014, 12:12 PM
psykokid
Jake
1997 Disco
So David, how was the trip? I read that a disco II had some problems on the first day. Did the defender fair well? From looking at few pics i've seen so far there were at least 4 Defenders on the trip.
Old November 24th, 2014, 01:31 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
After the fact, but.. I would suggest 2 small items to add to the list:
1) bring plenty of extra fuses..
2) replace your old clutch torsion pedal spring - it takes 5 mins (or bring an extra)
I am on my 3rd since 2001, so it is a good spare part to have kicking around.
I wouldnt want to be out in the middle of no-where-ville when its breaks.
http://www.defendersource.com/forum/...eferrerid=6308
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old November 25th, 2014, 03:36 PM
petminded's Avatar
petminded
David
Thank you all for your input. I'm sure the oil cool lines would have been the death of my D90 if I didn't have your advice.
Yes, we had 4 D's. Two 110s, and Two 90s. I was the only soft top and only manual out of 18 trucks. So I had different issues with driving (and breathing) then the rest. No one could advise me on some questions I had.
The only issue I had with my D - other then my lack of driving experience - was the headlights. after a very late start, drivingat 2:32am the night before with just 4 hr of sleep the headlights went out in the middle of BFN at 80 mph. Turned out to be the headlight switch.
Anyone know where the best place to get one with out spending my weekly coffee allowance?
Sadly this is where I depart with my D90. It's been great to me and in very good mechanical shape. But I need something the wife will get into and one that will keep the dust on the outside so I can breath.
ID:	107521   Click image for larger version
Old November 25th, 2014, 03:39 PM
petminded's Avatar
petminded
David
This was most of the groop.There was a 1993 diesel 110 with a 2 inch Old Man lift, and a 1997 D90 plus some others behind me.
Old November 25th, 2014, 03:44 PM
Sometimes it pays to be in the front of the group.
Old November 25th, 2014, 03:53 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Attachment 107524
Looks like a great trip. From the shadow, please post your GoPro footage as well.
Old November 25th, 2014, 04:10 PM
psykokid
Jake
1997 Disco
Not sure of where to source the HL switch at the best price, but make sure you add a relay harness for the headlights. It will keep the higher voltage from running through the switch and frying it.
Something like this would do: http://www.painlessperformance.com/w...v.php?sl=30815 Only thing you would have to do is extend the power wire so it would reach the battery box.
How about finding a fiberglass top for your ST? That should seal out the dust a lot more than the ST sides normally do. Is it just the dust/wind that keeps your wife out of the Defender?
We'll have to coerce Baldewin into coming out for a trail run up to Big Bear. His 90 is manual gearbox as well, with even less oomph than yours has since its a 2.5 diesel. With the auto gearbox trucks you can just line it up and bumble over stuff whereas with a manual gearbox you have to finesse things a bit more..
Old November 25th, 2014, 04:33 PM
down_shift's Avatar
down_shift
Russell
Its most likely your head light switch. Get a relay harness before you replace the switch.
-Jeff
Or new switch and replace the headlights with LEDs. No need to futz with the OEM wiring then.
Old November 25th, 2014, 04:58 PM
petminded's Avatar
petminded
David
It's a comb of things. The dust is for me. The comfort is for the wife. But being able to fit my fur children in with all the gear is for both of us.
ID:	107538   Click image for larger version
Old November 25th, 2014, 05:06 PM
petminded's Avatar
petminded
David
When my copilot finishes the footage I will post the GoPro vid. Do I need to create a link or can I post the vid here.
As for Baldwin, it would be great to meet him. But it did feel good to know I had one of the oldest trucks and a hand cap (my tires are some street version of off road) but made it to the end without any problem.
ID:	107541   Click image for larger version
Old November 25th, 2014, 05:09 PM
petminded's Avatar
petminded
David
Oh yea. Any suggestions on cleaning out the interior? I know the ecu and my stereo doesn't like water too much. So is there another option?
Old November 25th, 2014, 06:38 PM
psykokid
Jake
1997 Disco
Shop Vac it all out and then wipe down with a damp microfiber wash mit. Then go back in with compressed air to blow out all the dust from all the cracks and crevices and then repeat the Shop Vac / Damp Wash Mit / Compressed air routine as needed.. I'm still cleaning out all the dust from my truck when I led Miller Jeep Trail last month. I usually just stop caring after a while, but my wife is usually grossed out by the thick layer of dust all over everything.
MF Wash Mit I'm referring to btw:
Old November 25th, 2014, 06:58 PM
petminded's Avatar
petminded
David
Thanks!
Old November 25th, 2014, 07:20 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Yeah you have your hands full for sure!
Old November 25th, 2014, 08:51 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Do the bestop sides really let in that much dust? wow
d90 roll bar or trade d90 for d90 SBrick Wanted 22 January 16th, 2012 11:05 PM
