Weak Idle - Defender Source
Old March 6th, 2008, 06:28 AM
saber6's Avatar
saber6
gh
Weak Idle
My 1997 SW is picking of the sniffles, she runs superbly from start and and I have had no complaints for years now (she is a garage queen getting only 1k miles a year at best). However lately after she is warmed up and running I've noticed her idle gets very weak and accasionally stalls out. So bad so that I have to keep my foot on the gas to keep her rpm up to get through a stop light. After I shut her down for a while (maybe 30mins or more) she runs fine again until she heats back up.
I was thinking it could be bad gas, she does sit for long stretches but now I am thinking it may be something more. Let me know your thoughts and thank you very much. gh
Old March 6th, 2008, 08:03 PM
If it really is just a low idle and nothing else seems to be affected, you can adjust the idle speed. If it has never been adjusted there is a little cap over the hole that you have to drill a hole in and pry it out (i'm told put a screw in it and pull). This is on top of the plenum where the air intake is.
Oh, this is on a 94, but I assume the 97 is the same.
charles
Old March 6th, 2008, 08:42 PM
"you can adjust the idle speed"
DO NOT DO THIS!
You will mess up future diagnostics.
gh, do you get a check engine light?
As a start I would pull and clean the stepper motor. It could be a bunch of other things, but they are more time consuming and difficult to diagnose.
Old March 6th, 2008, 09:06 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Its not the fuel. Mine does the same thing every month or two.
And hay
And I love you too
Old March 6th, 2008, 10:16 PM
Grover's Avatar
Grover
Question
Could it be the Stepper Motor???
Old March 7th, 2008, 12:45 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I'm also on the list of suggesting checking the stepper motor.
If the idle is too low, the computer should automatically increase RPM's to compensate. If the idle is naturally too high, then you would manually adjust it down.
Could also be dirty oxygen sensors, but normally that would trip the check engine light. Don't have that on, do you?
One thing I do recommend in your case is to put some miles on it. If you're just doing a few short trips once in a while, and not letting it run at temperature very much, you're constantly running it in "warm-up" mode. When the engine is still warming up, it ignores most of the sensors and runs rich. If this is how the engine is running most of the time, you're going to clog up the cats eventually. So when you do drive it around, make sure to give it some good amount of time to run. This burns all that extra crap off your O2 sensors, out of the cats, and keeps the engine from gunking up.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 7th, 2008, 07:37 AM
As far as the idle adjustment goes, count the turns and you can always revert. But Ron is probably right - mine has never been adjusted and doesn't appear to need it if everything else is working properly.
I agree with Hans - put some miles on it. My D90 had a weird stalling issue (but not an idle thing) and it went away after I put some miles on it. Prior to that I was just doing lots of short slow trips.
Old March 7th, 2008, 10:35 AM
Also, much different on GEMS than 14CUX to adjust idle
idle
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
fluctuating idle KeithElisa Defender Technical Discussions 15 May 31st, 2006 08:38 AM
High Idle tron Defender Technical Discussions 5 February 15th, 2006 03:33 PM
d90 bogging & hesitating off idle vesparover Defender Technical Discussions 11 April 9th, 2004 04:03 PM
