Way too much Steering play - Defender Source
Old October 3rd, 2015, 03:40 AM
thehundredth
PJ
1995 D90 Beluga Black
I have way too much play in my steering that has progressively gotten worst. So much play that I prefer not to drive with my 5 year old. I prefer to buy the parts and let my mechanic do the labor. But where do I start?? My pitman arm totally needs to be replaced. Steering box has a small amount of play, damper shock needs replacing, etc. Basically, the front end has been ignored since purchasing the truck. Time to get it done. Any advice/help as to where I begin, parts, etc. would be appreciated. Thanks in advance.
Old October 3rd, 2015, 06:16 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
You can overhaul everything in a couple hours. There is a bolt on top of your steering box to adjust the backlash of your steering. Clockwise to tighten it up, I would do a quarter turn at a time and then check.. As for the steering dampener and steering links order everything online and you can get it done for less then $100. Good luck
Old October 4th, 2015, 03:56 AM
thehundredth
PJ
Wow. Great information. Thank you.
Old October 4th, 2015, 09:17 AM
sandman913's Avatar
sandman913
1985 110 200 Tdi
Have a look at the steering column u-joints while you're at it. Changed out mine and made a huge difference.
Old October 4th, 2015, 04:21 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
I tightened up the adjustment which worked for a few hundred miles but finally just replaced the box and arm which can be a PITA to remove so easier to just replace both...nice and tight now...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old October 4th, 2015, 04:42 PM
Swivel ball tension as well
Old October 25th, 2015, 09:35 PM
Promark420's Avatar
Promark420
Bryan
97 NAS D90 SW #0221
Digging this up from a search.
I'm a Defender owner noob wondering if all 90s feel a little vague or not centered when doing highway speeds. I realize this could be an alignment thing, but I want to know what to expect when doing 60-70. Right now mine feels a little, hmmm, unstable may not be the right word. It feels like I'm driving in swirling winds, constantly making little adjustments to stay in my lane, and that doesn't seem normal in any car I've driven. I'm taking a road trip from Atlanta to Asheville in two weeks, so I want peace of mind. If that's how they drive, fine. I'll be extra alert. For what it's worth, I'm getting new tires this week to replace the visibly cracked and 8 year-old BFG ATs and checking alignment. Thanks in advance.
Old October 25th, 2015, 09:42 PM
Have you ever had the bushes replaced?
Shocks replaced?
Old October 26th, 2015, 06:43 AM
Promark420's Avatar
Promark420
Bryan
97 NAS D90 SW #0221
Shocks replaced?
Shocks I know were replaced. Not sure about bushes. It's not in any paperwork, but I'm missing some records.
Old October 26th, 2015, 07:30 AM
Ok so thats one possibility. They are worn and need replacing. While you are looking around, just check that all the nuts and bolts are properly torqued.......
Old October 26th, 2015, 07:01 PM
Promark420's Avatar
Promark420
Bryan
97 NAS D90 SW #0221
Good to know.
So driving on a highway shouldn't feel treacherous? I haven't experienced any death wobble, which sounds rather scary.
How much is too much??? Azarur Truck Build-up's & Restores 71 April 5th, 2015 01:55 AM
Work to play ratio way off GaryBaxter Misc. Chit-Chat 3 May 21st, 2012 02:35 PM
Quick Steering Fix - play in the steering wheel. bossman429 Defender Technical Discussions 5 February 27th, 2012 08:37 PM
Sagging Suspension: How Much is Too Much? aclarke Defender Technical Discussions 9 June 19th, 2007 04:41 PM
