Waterproofing Troy Smith boxes? - Defender Source
Old June 6th, 2006, 01:28 PM
Matt Taylor
Matt Taylor
So, I ruined this chick's purse she got from her grandmother. Whoops. We locked it in one of my Troy Smith boxes with the surrey on and it rained.
Is there anyway to keep water from getting in these things, other than putting the soft top on?
Thanks.
Old June 6th, 2006, 02:29 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
I don't know that you could "water-proof" them but you can possibly make them "water-resistant?" I think the most difficult task would be limiting water ingress via the hinge. I would explore the possibility of affixing neoprene or some other flexible polymer (maybe a door seal?) over the entire top of the box. That way when the lid closes and is locked the seal sits snug against the lid or another seal.
DJ
Old June 6th, 2006, 02:45 PM
Matt Taylor
Matt Taylor
yeah, the hinge seems to be the difficult part. What does everybody else with soft tops do about this? Live with it? Drill holes for the water to drain?
Thanks.
Old June 6th, 2006, 04:32 PM
Hmmm, I painted mine with Hurculiner (Hinges and all) and they don't seem to leak. Ohhh buttt Mine has the tops on backwards! So that lip on the inside is on the same side as the hinge,,,, I'll have to tell Troy about this for later revs as it may be what makes my boxes water tight.
Old June 6th, 2006, 04:45 PM
Troys
Troy Smith
1995 D90 SW
There was a guy that inquired about waterproofing his boxes in a ST. I gave it some thought and replied to install a rubber weatherstrip from the local hardware store upside down and secure it with the hinge screws. I.E. the thin metal part of the weather strip bolts down with the hinge screws leaving the rubber "sweep" sticking up. When the lid is closed, it curls the rubber "sweep' over thus preventing water intrusion, mostly anyway. I also recomended adding foam weatherstripping along the entire lid on the other 3 sides. I never heard back so I cannot tell you if that idea worked.
If someone actually does this, let me know how it works and post or send me some photos.
Thanks!
Troy
Old June 6th, 2006, 09:20 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
i put rubber weatherstripping around the 3 sides of the lid as troy mentioned and it's worked well so far.
Old June 7th, 2006, 04:57 PM
Matt Taylor
Matt Taylor
Thanks, guys. When I find some damn time I'll fool around with this and will post any results.
roof, water
Ideas for affixing Troy Smith toolboxes fenwaystan Defender Technical Discussions 5 August 1st, 2009 12:41 PM
Troy Smith storage boxes dbj836 Defender Technical Discussions 5 March 17th, 2009 11:01 PM
Troy Smith Contact Info? fleabus Misc. Chit-Chat 2 July 17th, 2006 04:30 PM
Troy Smith? Matt Taylor Misc. Chit-Chat 3 December 9th, 2005 04:31 PM
Tool boxes - Troy Smith jabber Misc. Chit-Chat 2 March 8th, 2005 09:55 PM
