Water Underneath Fuel Cap - Defender Source
Old December 15th, 2011, 01:38 PM
Hinckley423's Avatar
Hinckley423
Charles Joerss
1995 D-90 #2812
I went to put some fuel in my D90 yesterday and when I took the fuel cap off there was fair amount of water in the cap itself. The truck was outside for a few days and we've had some rain where I am. The cap looks okay but then again I dont know much about it. Should I replace the cap? I believe its original to the truck (1995). Thank you.
Old December 15th, 2011, 02:07 PM
Rugbier's Avatar
Rugbier
Gustavo
Maybe is evap water from the tank.
Clean cap at gas station, run 2 bottles of HEET on your next fill up and double check
NO SIGNATURE
Old December 15th, 2011, 08:55 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Most likely condensation - you have a locking fuelcap right? I doubt rain water got in there and if it did it would trickle down into the tank.
Always a good idea to keep as full of a tank as possible in the colder months.
My cap too has some condensation on it when I go to fill up.
Old December 15th, 2011, 09:29 PM
Hinckley423
Charles Joerss
1995 D-90 #2812
I ordered a new cap just incase and I'll use the advice I've been given. The tank was closer to the empty side when I saw the water and it had been sitting like that for a bit.
Thank you for all the suggestions.
Old December 18th, 2011, 11:53 PM
Charles:
Sounds like you could benefit from this as well:
http://www.defendoor.co.uk/
cap, fuel, gas, gas cap, water
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
