Water temp sending unit 4.0 - Defender Source
Old March 23rd, 2011, 05:06 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Please see pic. Which one is the ecu sending and which one is the gauge? I think the two wire up front is ecu andthe single wire is gauge (behind).
Thanks!
Nuck
Old March 23rd, 2011, 05:52 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
The ECU one is the two wire one that is leaking in your photo. The single wire one is just for the gauge.
Old March 23rd, 2011, 06:44 PM
97-D90-736
Nick Vogel
Thanks. Does anyone happen to know the size of the gauge ending unit? I want to change out the gauge but need to match S.U.
I'm fixing the ecu one now.
Old March 23rd, 2011, 06:59 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
i would leave it alone. People have all kinds of issues with the aftermarket ones. They work fine as long as the connection at the sending unit is good and clean. The gauge rarely goes bad....I've seen maybe 5 go bad in 20yrs! Spend the $$$ somewhere else.
Old March 24th, 2011, 02:32 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
You might use an infrared thermometer at the sending unit to determine if the gauge is bad or the sender. Unfortunately, I had a bad gauge and replaced a lot of stuff (fan clutch, thermostat, OEM sender) for what ended up costing like 60 bucks for a new VDO gauge and sender. They came from NAPA and the part numbers are on here somewhere for the replacement, if that's how you have to go.
Old March 24th, 2011, 03:42 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Just pull off the wire that goes to the sender and ground it. If the gauge does a full sweep and ends deep in the red than it is good. If it hangs or stops short of the red than the gauge is suspect. Simple tests are the best!
water
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
4.0 Temp sensor Size 97-D90-736 Defender Technical Discussions 2 December 31st, 2010 12:26 AM
Temp sending unit 3.9L vs 300TDI - different range? jaherring Defender Technical Discussions 8 October 4th, 2010 08:22 PM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
