Water temp guage wiring - Defender Source
Old April 24th, 2013, 04:52 PM
Ignotus
gene
1960 109, w/200TDI
Hi,
I picked up a water temp guage for my 2.5Dt. On the back it has 2 spade connectors 1 male and 1 female. Can anyone tell me which goes to the sender and to the power? I don't have the orginal wiring because this is an engine swap into a Series 2.
gene
Old April 26th, 2013, 12:07 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Hey Gene!
I hope things are treating you well. As I have struggled to get my temp sender and gauge to work right I can tell you straight off which is which (since I have your engine's original wiring)
Male spade is for power in (as the wire for this is a green wire with a female end)
Female end would be for the wire from the sender as it had a male spade. (changed it for the VDO gauge, and finally threw in the towel and went with a VDO mechanical, no idea why anyone would even mess with the VDO electrical, same price for the mechanical, no gremlins)
Old April 26th, 2013, 12:35 AM
Ignotus
gene
1960 109, w/200TDI
Chris,
Thanks for that! Been getting the 109 going. I started the motor 2 weeks ago for the first time as I sorted out the starting circuit. Couldn't run long since there was no air cleaner, throttle cable or fluid in the power steering pump(no hoses).
Here's the videos I took; try not to laugh too hard!
My blog on the rebuild; http://poppageno.blogspot.com/
I should be driving it by the end of May if not sooner!
gene
Old April 26th, 2013, 07:55 PM
El Solis's Avatar
El Solis
Chris Solis
looking good Gene, glad I could help!! Should Have let me know you were looking, I have the gauge that went with the sender in truck that I'm not using.
Old April 26th, 2013, 10:47 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Need to remove the tape from the turbo, getting no air man
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
water, wiring
Temp guage problem TDI Guy Defender Technical Discussions 24 June 28th, 2013 10:42 PM
Temp Guage Position willtillery Defender Technical Discussions 1 October 15th, 2005 05:11 PM
aftermarket temp guage options draaronr Defender Technical Discussions 7 January 4th, 2005 02:33 PM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
