Water Temp Gauge swap: something is wrong - Defender Source
Old November 24th, 2015, 08:36 AM
WG_moots
Wilmer
I finally got around to swapping out the water temperature gauge and sensor from stock to VDO. I didn't have time to swap the sensor so I had to drive around for a day with the mismatched sensor and gauge. AT this time the gauge didn't move much and hovered at around 100F
Last night I got around to swapping out the sensor and got everything cleaned up. I turn the key and the gauge goes straight to the max with the engine off:
I took the dash apart again and double checked all the connections. Re-read the install thread to make sure I wasn't missing anything. Everything looked good ... I'm stumped.
Any ideas? Maybe I need to rerun the ground??
thanks.
Old November 24th, 2015, 08:46 AM
BlackField's Avatar
BlackField
Oscar
D110
Which sensor did you use? Did you use teflon tape?
Old November 24th, 2015, 09:00 AM
WG_moots
Wilmer
Originally Posted by BlackField View Post
Whick sensor did you use? Did you use teflon tape?
I used the sensor that came with the VDO gauge. I did not use teflon tape ...
Old November 24th, 2015, 09:11 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Oscar makes an excellent point which is are you sure the sending unit is adequately grounded.
Also VDO gauges cannot be wired like the stock gauges using the stock wiring.
They require separate power and ground wires to get a correct reading.
For the gauge to peg, the wire from the sender is generally grounded, but drawing a ground through the gauge can also cause the needle to peg.
RDavisinVA
Old November 24th, 2015, 09:49 AM
Take the sensor wire at the sender and disconnect it. See where the gauge goes. Then ground it and see where the gauge goes. This will verify that the wiring is good.
Maybe take a pic of the gauge connections and post it up.
Old November 24th, 2015, 12:04 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Originally Posted by rdavisinva View Post
Also VDO gauges cannot be wired like the stock gauges using the stock wiring. They require separate power and ground wires to get a correct reading. For the gauge to peg, the wire from the sender is generally grounded, but drawing a ground through the gauge can also cause the needle to peg.
There is only one ground connection point for the gauge. How/where do you connect the second ground for the sensor? On mine i ran all the gauges 100% off the stock wiring. I also took the time to go through the entire harness and cleaned all ground connections to chassis and body, I also replaced the chassis to block ground and battery to chassis wires. I did all this work at the same time as my chassis replacement and in the 15000 miles since have yet have any electrical problems.
Ryan
84 110SW County LHD
07 L322 Vogue
Old November 24th, 2015, 12:14 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
As red90 says disconnect sender wire and touch it to ground you should get full deflection of the gauge, if this a single wire sender, if it's a two wire sender it needs to be earthed. The single wire sender earths it self to the engine. If the sender wire is disconnected and you still get full deflection you have a short in that wire. Run a new temporary wire from the gauge sender input of the gauge to the sender to check.
It's not rocket science. If it's still wonky you gots a duff unit
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old November 24th, 2015, 12:30 PM
WG_moots
Wilmer
Here is how I wired it ... I'm thinking that I should have connected it to the top where it seems to be isolated by the black rubber:
Old November 24th, 2015, 12:32 PM
That is a single wire sensor but it attaches to the tip of the sender. You are just grounding it out like that.
Old November 24th, 2015, 12:35 PM
BlackField's Avatar
BlackField
Oscar
D110
Yeah, you pretty much just grounded the sender. that T slot on the top is where you want to slide a female spade type connector on to.
Dammit Dave I went outside for my picture!
Old November 24th, 2015, 12:46 PM
roverman2010
1985 LR 90 200Tdi
Sorry couldn't help it,
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old November 24th, 2015, 02:14 PM
WG_moots
Wilmer
is right ...
thanks for the help. I thought it didn't look right ... and obviously, didn't work wired that way.
water
Engine Water Temp Gauge 80% Dead RBBailey Defender Technical Discussions 11 March 26th, 2015 12:20 PM
Water Temp Gauge javelinadave For Sale - Parts 2 September 7th, 2014 04:33 PM
Water temp gauge bcourtney Series Technical Discussions 3 May 27th, 2012 08:10 AM
oil pres + water temp gauge??? revtor Defender Technical Discussions 1 July 10th, 2007 09:35 PM
Something Wrong With The Front End? The Wizard Defender Technical Discussions 13 October 4th, 2006 11:51 PM
