Water pump tensioner - Page 2 - Defender Source
Old March 15th, 2005, 10:15 AM
Damn, I'm out of the loop! Was the damage from the water hole too much? Jesus I feel bad egging you on now
Ok, so what did you stuff in there? Let me guess - diesel right?
I ordered 2 bearings, and will attempt to press out the old. I have a number of little projects going on mine - waterpump/tensioners/belts/viscous fan clutch and the master cylinder is leaking so I got a seal kit.
But with it all open like that, I am dying to relocate my transmission cooler and go with electric fans. Will be searching the board for info on what/where a '97 D90 does for a tranny cooler.
ttyl
charles
Old March 15th, 2005, 12:07 PM
Nope a 4.0, I'm poor so no diesel.
Old March 27th, 2005, 12:16 AM
Just wanted to post what I ended up doing. I was quoted $250 for a replacement tensioner, and $65 for the bearing. I got two bearings and a local shop replaced them both for $38, for a total damage of about $170.
I still can't get over some of the insane LR pricing...
charles
water, water pump
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
Water pump replacement mwmcgehee Defender Technical Discussions 6 June 2nd, 2004 12:00 PM
